I have a 3yr old Rotel Amp RB1080 with RC1070, problem no sound all lights working all fuses good.
  • 4,234 Answers
This unit is in protect mode. The outputs are disabled to prevent further damage to either the amp or the speakers. If you are not comfortable with electronics, bring this to a servicer. Expect a parts cost in the range of $15-$40 plus the local labor rate.
Dan
Posted on Apr 09, 2008
Rotel RHB-10 amp not firing up anymore; protection light/cicuit not engaging
Check the rest of the power supply, for example the transformer if there is no power at all. If you are getting some indication of power, check the voltage regulator circuit.
Dec 19, 2015 | Rotel Audio Players & Recorders
Rotel RHB-10 amp channel not working
YOU ARE NOT RIGHT IT SHOULD GIVE AT LAEST A LOW VOLUME SOUND WITH A LOT OF DISTORSION AND A CRACKING NOISE IF DOES I GUESS THAT YOU HAD THIS AMP IN A PLACE WITH A LOT OF HUMIDITY AND YOU HAVEN'T WORK IT FOR SOME TIME IF I AM RIGHT PUT YOUR AMP IN THE SUN AND WORK IT FOR 10 MIN WITH A 5 MIN BREAK LET ME KNOW THE RESULTS
Nov 14, 2012 | Rotel Audio Players & Recorders
Fuse for rotel amp for RB-870BX
IF THE FUSE YOU ARE PLACING IS THE SAME TYPE AS THE ORIGINAL YOUR AMP HAS A PROBLEM WHAT YOU MUST DO IS TO SLIGHTY INCREASE FUSE BY 100 MAMPS PER TIME IF IT IS IN THE TRANSFORMER CIRCUIT YOU CAN INCRESE IT BY 2 AMP MAX IF IT IS IN THE MOSFETS CIRCUIT YOU CAN INCRESE IT BY A MAXIMUM OF 500MAMP LET ME KNOW THE RESULTS
Mar 04, 2012 | Rotel Audio Players & Recorders
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4...
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Dec 21, 2017 | Rotel Audio Players & Recorders
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
KEEPS BLOWING SOUND FUSE
When you refer to the "sound fuses" are you referring to the speaker protection fuses or the power supply fuses?
Dan
Jan 14, 2009 | Audio Players & Recorders
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
May 09, 2008 | Audio Players & Recorders
Rotel Amp center channel out
if you say you checked the wireing ,did you check the speaker. disconnect on of the other speakers and connect up the center to see if you get sound. still no sound speakers bad. Got sound try unpluging unit for a couple of hours then try it again. still no center . Time for the repair shop. Good Luck
May 26, 2006 | Rotel RMB-1095 Power Amplifier
61 people viewed this question
 Grubhead
Grubhead
