Question about Shuttle XPC PC Desktop
You press the button and it donest turn on all the time
  • Shuttle Master
  • 5,660 Answers
DO NOT OPEN A POWER SUPPLY!!!!
NEVER!
Inside an SMPS, (Switched Mode Power Supply), are Electrolytic Capacitors.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
http://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.png
http://en.wikipedia.org/wiki/File:Capacitors_electrolytic.jpg
(Radial. The bottom capacitor in the photo)
Electrolytic Capacitors slowly build up a charge, then release it all at once.
You can compare it to a large swimming pool being filled up with a garden hose, and then one wall of the pool being taken down all at once.
At the bottom, of the Radial (Style) Aluminum Electrolytic Capacitor shown in the above photo link, are two leads.
One is Positive, the other is Negative.
Touch your finger/s to the terminals on the bottom of one of these babies, and the shock can be BAD to FATAL!
If your fingers touch, and complete a circuit that one, or more capacitors are in, the shock can be BAD to FATAL!
Don't open that power supply!
Besides, a fuse goes out All At Once.
There is no work a little bit, then turn off.
It just goes Poof!
(The fusible element inside burns into two separate pieces)
Now,
"You press the power button, and it doesn't turn on all the time"
As has been suggested, I also concur that you have a bad power supply.
But you could also have a bad Power On switch, located inside that plastic Power On button.
This is an example of a Power On switch, that I have found fits a lot of computers,
http://www.directron.com/atxswitch.html
I'd like you to get this switch, and install it.
From there the diagnosis will go to the Power Supply.
Also would like you to make sure the ram memory is seated tight, and the Processor fan is spinning, and looks to be spinning at the right speed.
If the fan spins a few times, and stops, then spins a few times, you know the fan has a bad bearing. Replace.
If it looks to be spinning too slowly also, you'll know it
Be sure to follow anti-static precautions before you reach inside your computer, and the computer is unplugged from power.
If you do not know what anti-static precautions are, I'll be glad to tell you. Simply state so in a Comment.
(Believe upper right of your page)
As for the Power Supply test, you need either a multimeter, or a power supply tester.
An inexpensive multimeter, that will work just fine for this application, ranges from $6 to $12. The Voltages are only 3.3 Volts, 5 Volts, and 12 Volts. (DC)
Two C cell flashlight batteries are 3 Volts. (DC)
Your computer power supply puts out three main Voltages, as stated above.
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
Orange insulated wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts
ANY Black insulated wire is a Ground wire.
This is DC Voltage.
There is a Positive, and a Negative.
The Positive (Red) probe lead of the multimeter touches a power wire. (3.3, 5, or 12)
The Negative (Black) probe lead touches ANY Ground wire. (Black)
IF, the 12 Volt power rail shows 11 to 13 Volts, the diagnosis indicates the Power Supply to be good.
(However read on)
IF the 12 Volt power rail shows 11 Volts, or less, the Power Supply is bad.
This is an example of a power supply tester,
http://www.directron.com/pst03.html
Posted on Jun 06, 2010
Testimonial: "thanks for the info but it did not fix the problem Thanks anyway"
  • joecoolvette
    joecoolvette Jun 06, 2010
    "IF, the 12 Volt power rail shows 11 to 13 Volts, the diagnosis indicates
    (However read on)"
    The Power Supply has to be under a load, to come close to an accurate reading.
    All of the yellow 12 Volt wires end on one terminal post, inside the Power Supply. (On the circuit board)
    Same thing with the 3.3 Volt (Orange), and the 5 Volt (Red)
    This means for example, you can disconnect one power cable from a hardware component, such as one of the optical drives, (CD/DVD drive), and test the (Yellow) 12 Volt power wire in that 4-pin Peripheral connector.
    http://www.playtool.com/pages/psuconnect...
    You will be testing the 12 Volt power rail.
    You will have a load, because of all the other hardware components that are using power.
  • joecoolvette
    Really, well I appreciate the rating, you are most kind!
    (Sincerely)
    You conducted these tests already, or did you find the problem to be elsewhere?
    Curious so I can add it to my 'knowledge bank'.
    Always willing to learn.
    Scholar:
  • 94 Answers
Just check the power supply of your PC if they are working. If the power supply are did not work, just check the fuse inside because it could be blown. Only the power supply have a problem if your PC did not power on. But if the power supply of your PC have a big damage inside, I recommend that you replace the whole power supply.
Set the clock on Eclipse CD3414? step by Step
Turn [SEL] button to select CLOCK ADJ.
Press the [SEL] button. The clock adjustment mode is activated. Turn [SEL] button to display the item to be selected for adjustment. Hours, minutes or exact hour will be switched each time the button is turned.
Press the [SEEK /FAST ] button. [SEEK ] button: Turns the time forward. [FAST ] button: Turns the time back. To set the clock to 0 minutes, 0 seconds (an exact hour), press the [SEEK /FAST ] button.
For example: At 3:29: Pressing the [SEEK /FAST ] button returns to 3:00. At 3:30: Pressing the [SEEK /FAST ] button advances to 4:00.
Press the [RTN] button. At this time, other adjustments can also be made in Function Mode. 6 Press the [FUNC] button to exit Function Mode.
Also, you can read the manual here:
http://www.eclipse-web.com/us/download/manual/manual/pdf/CD3414(1-1455A).pdf
Jan 27, 2017 | Cars & Trucks
Turn off alarm without key fob
First off, you need to know the PIN.
Setting the PIN is as follows:
Think of a five-digit PIN, and write it down. Think of this set of numbers as a password for starting your bike and disabling the alarm during those times when you don't have your fob.
Turn the ignition key on, then off, then on, then off, then on again. Then press the left turn-signal switch twice. Press the right turn-signal switch once, and the current PIN should appear in your odometer.
Be sure the first digit of the PIN is flashing. Enter the first digit of your new PIN by pressing the left turn signal to cycle through the numbers.
Press the right turn signal once to switch to the second digit, and select the correct number with the left turn signal. Repeat this process until your new PIN is entered correctly.
Press the right turn signal once, then turn the ignition key off to save the PIN you selected.
Now, how to disable:
Let's assume for simplicity that your code is set at 31313 and you wish to use the manual disarm of the security system using the directional switches as if you lost your fob and cannot disarm the system.
Your security system will disarm the bike and it cannot be started without deactivating the system first.
If you are unsure of what the manual code is refer to the top of this page or check with your dealer and set one if it has not been set by them.
Again this is based on your code being 31313 just to make it easier to understand.
1. Turn the ignition to Accessory.
2. Press both turn signals. (security light should flash rapidly)
3. Press left turn signal button 3 times (the 1st "3" of the PIN). Press right turn signal button 1 time (to "set" the code number).
4. Press left turn signal button 1 time (2nd number of PIN). Press right turn signal button 1 time.
5. Press left turn signal button 3 times. Press right turn signal button 1 time.
6. Press left turn signal button 1 time. Press right turn signal button 1 time.
7. Press left turn signal button 3 times. Press right turn signal button 1 time.
Security light stops flashing and security system is disarmed.
If you've changed the number, use your new number instead of 31313.
Dec 25, 2013 | Harley Davidson Motorcycles
Clutch set up
you will have to replace the clutch located on the bottom rear of the mower, its very easy.
Apr 25, 2013 | Mtd Garden
How could we set default page setup from 11 inch to 12 inch in epson fx-2175
Dear friend,
Jus do the following:
press 2&3 button simultaneously when printer is power on.
Press itemdown (1) one time press set button 2 times
turn off and turn on pinter
Press set button once
check the print for 12 inch
Mar 11, 2011 | Epson Office Equipment & Supplies
I have model cd 3424 and cant set clock
This was taken from a radio similar to yours. Same brand but different model. Hopefully it'll help.
(Also the "SEL" button it talks about is a big round button/knob on the right of the unit.)
Setting the Time
This receiver uses the 12-hour display notation.
1 Turn [SEL] button to select CLOCK ADJ.
2 Press the [SEL] button.
3 Turn [SEL] button to display the item to be selected for
adjustment.
button is turned.
4 Press the [SEEK / FAST] button.
[SEEK] button: Turns the time forward.
[FAST] button: Turns the time back.
press the [SEEK / FAST] button.
For example:
At 3:29: Pressing the [SEEK / FAST] button returns to 3:00.
At 3:30: Pressing the [SEEK / FAST] button advances to 4:00.
5 Press the [RTN] button.
Function Mode.
Mar 02, 2011 | Eclipse CD3422 CD Player
I downloaded the you tube toolbar but it doesn't show up in IE
it donest show up on google chrome but on internet explor 7
Feb 27, 2011 | YouTube Videos
Error code E27, ink absorber is full. Call service.
Follow these steps :
1. Unplug the power cord
2. Press and hold down the Stop / Reset.
3. Insert the power cable
4. Press and hold down the power button (the button Stop / Reset fixed in press)
5. When pressing the Power button, then release the button Stop / Reset.
6. Press the Stop / Reset 2 times then release the Power button.
"Wait until the digit 0 appears in the display"
7. Press the Stop / Reset 1 time.
8. Press the Power button 1 time, the printer will print a sheet of paper.
9. Press the Stop / Reset 2 times.
10. Press the Power button 1 time, the printer will mecetak a sheet of paper
11. Press the Stop / Reset 3 times.
12. Press the Power button 1 time. (No printing)
13. Press the Stop / Reset 4 times
14. Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
15. Turn on the printer.
16. E27 error message is gone & the printer is running normally.
Oct 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How do i reset a canon PIXMA MP150 printer after the "waste absorber is full" message shows????
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon P170-DH
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Jan 10, 2009 | Canon P170-DH Calculator
Need codes to control symphonic 27" tv using rca universal remote control type rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Tips
  • Turn on TV
  • Hold in the TV button and the ON/OFF button until the ON/OFF button stays lit
  • Press the PLAY button every 5 seconds until the device turns off
  • Press the REVERSE button every 2 seconds until the device turns on
  • Press the STOP button to lock in the code...the remote should work now.
  • Important to press reverse button every 2 seconds, not just once.
Good Luck!!
Aug 18, 2008 | Televison & Video
Shuttle XPC PC Desktop Logo
477 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
