Question about HP Compaq ProLiant DL380 G4 Server
Hp compaq prolaint dl380 g4 server no display on screen
    Problem Solver:
  • 8 Answers
Even with out the display, can you ping it from the network? If not I would power off the server. Unplug the power. Take the cover off the server, reseat the memory. Pullout the both power supplies and reseat them. remove any cards in the server except the disk controller. Reseat all the disk drives, make sure you put them in the same slot you pulled them from, even though it doesnt matter. Plug back in and see if you get a display. You can move the memory around also or take out some. If you are not getting an intermittent beep or a red display on the front panel, your system board may be shot.
Posted on Jun 25, 2010
  • HP Master
  • 4,924 Answers
If you mean that just shows a bue screen and no task bar or desktop ..this is probably from a virus attack that cause it ..Try to press ctrl+alt+del this should show the task manager and in the task manager run a new tas ...and lunch the windows explorer again ..
or just run from task manager the system restore..and try to restore it to an earlier date that worked..To do that pres those like I said ..and than in the task manager on screen choose file and new task (run) and type system restore..and hit enter ..ths should run it ...choose the date that you know it worked and run it ..If it do not restore you have to reinstall or ..to use it for the moment find the desktop address and add it in the start-up for that run MSconfig and press enter ..in the start menu ..choose normal ..and enter ..and choose restart ..it should get along well again..
Posted on Jun 03, 2010
  • md_syd Jun 05, 2010
    Dear
    At the time of booting only it does not show the dispaly and nothing is comming on the screen.
Unable to boot HP DL380 G4 with display message no signal on the monitor
Just Clear NVRAM (by SW6 maintainance switch )/ else systemboard has to be replaced
Aug 11, 2012 | HP Compaq ProLiant DL380 G4 Server
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
May 18, 2012 | HP Compaq ProLiant DL380 G2 Server
I have HP PROLIANT DL 380 (G4). I removed hard disk. Its start and few seconds restart again. its happening continuously. Any solution.
need to provide moreinfo.
is the server (prolaint DL380) constantly rebooting within BIOS mode or has it got to the stage of running windows.
The other item not mentioned here, is, IF the raid controller has failed, you will not see any disks initializing and would cause the system to continually reboot.
If it is an internal raid controller, it is part of the motherboard, you will need to contact HP to have it replaced.
If an pci related array controller .. i.e. separate to the motherboard, this will need to be replaced to see the HDD's.
Either way sounds like a hardware issue. Best to liaise directly with vendor to have the faulty components replaced.
Sep 28, 2010 | HP Compaq ProLiant DL380 G4 Server
HP DL380 no display on screen
does the server power on?
When i purchased my first DL380 i had a simular issue, as it turns out the datacenter i had purchased the server from, had installed a ILO replica type card. if you have the same card installed (it will have a ethernet port, power port, and video port) , this can be causing the issue, also, the card will be located in the PCI-X Slot.
Jun 03, 2010 | HP Compaq ProLiant DL380 G4 Server
Hp DL 380 G4 no display on screen, all the status lights are green
We had the same problem with a G5 version of the dl380, no video at boot or OS boot. This model fortunately had another video out on the front panel that worked. However, I believe that the G4 does not have that option coupled with using the Rage XL's from ATI for video. Have you tried installing another video card into the expansion slots for video? If you are able to, you may find that when you run your smartstart and load/reload the OS your video will work with the onboard.
Dec 03, 2009 | HP Compaq ProLiant DL380 G4 Server
HP DL380 G4 could not boot up. Nothing display as well. What's wrong with that?
make sure there is no disk in cd rom drive if there remove it and also check the amber led in front panel which is indicating the problem still if you are not able then open it and check the ram. And the power connector in motherboard and also the cmos battery or reset the bios.
Sep 15, 2009 | HP Compaq ProLiant DL380 G4 Server
No display on DL380 g4
This can be caused by a processor / VRM issue or even a system board fail. Try dropping to a single proc and VRM and swap test with the others.
May 01, 2009 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
832 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
