Watson FA 5441 TSF TV, the problem is no picture and no sound
Watson FA 5441 TSF TV, the problem is no picture, no sound and even no incate lighet. Open the rear cover and check the fuse. the fuse is good. what is the possible problem?
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-45605 rear projection tv
If the green light is not lighting up, you will need to check out the standby power supply inside the TV set, or if this set has a DM board, you will need to change the capacitors. Good Luck
Posted on Jul 14, 2007
  • 579 Answers
SOURCE: Philips CRT Rear-Projection TV 64P8342
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Most common death mode)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Posted on Feb 11, 2008
freetek
  • 5568 Answers
SOURCE: Turns on but no picture or sound.
There are not many things that audio and video have in common and the power supply section is most likely at fault.
If the system has an LED indicator and it isn't lit, the supply is probably the reason.
This is not a good place for users to troubleshoot and can be dangerous, even after the power has been off for an hour or two.
Posted on Mar 30, 2008
  • 2973 Answers
SOURCE: There is no picture after about 1-3 minute after
Check the display IC module for burst or bulged capacitors. If found any, they should be replaced with the ones with exactly the same specifications. You may also find some wax if the capacitor has burst or leaked.
Posted on Nov 26, 2009
  • 226 Answers
SOURCE: rca rear proj. 1993 model p46151wk tv just went
Take a look at CR4118, and the capacitors around the power supply regulator chip. You likely have capacitors that are dried out. They can take out the chip, and Q4101, the 'chopper'.
The web site: http://eserivceinfo.com/ has a program for the CTC169 series of RCA projo's that is very useful in finding the fault that causes the condition you describe. Just enter ctc169 into the search box. Or go to this URL:
http://www.eserviceinfo.com/downloadsm/4999/RCA_proscan.html
tom
Posted on Feb 25, 2010
Code watson tv fa 3577t
002,036,000,065,019,087 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 10, 2013 | Televison & Video
Looking at new freezer, what is the difference between Turbo air TSF-23sdr and TSF-23nm? product specs would not download. thks
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
Sep 22, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Dell 23'' TV/Monitor has stripe of raster in screen, just to the left of center. Comes and goes, sometimes it's just wavy, sometimes it's completely black.
Check main power supply DC capacitor.If this becomes dry this wiil fault could be due to intermittent contact of the EHT at picture tube body. Other possible fa Remove and reconnect the EHT cable at picture tube end. Before attempting switch off T V. Remove all electrical plug connections. Wait for few minutes for the EHT to discharge. Ease the suction cup that is hugging the picture tube body. By keeping the circular flaps folded by finger try removing the folded pin clip that is on the glass body. Clean and re position the clip. Attach back the suction clip.
Take care high voltage present at picture tube even the TV is OFF and plugs removed.
Jul 06, 2010 | Televison & Video
Seem to have developed a problem with my audio recording and playback using Roland's FA-66 (Editrol). I use Cakewalk SONAR, Sony Sound Forge and Vegas Video softwares, and all of them show the same sound...
www.rolawww.scottyp-music.com/geardos/?p=21 nd.com/products/en/_support/dld.cfm?...FA-66
try these 2 sites, i believe they have some good info you need and will probably solve your issue. ive heard some horror stories about norton. unistall and see what comes about. it seems as though too many connections are going to screw this item up and norton will do the same.
Nov 15, 2009 | Edirol FA-66 Sound Card
Picture will not come on but sound does
It can be the backlight inverter board is bad or the power supply is not supplying power to the inverter board.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Circuit diagram of grundig 5441 tv
Dear Sir,
According to your request i am providing download link
Circuit diagram for Grundig 5441 tv. If you have any problem regarding this issue come back with more information about the problem,we will glad to assist you
Preview
in PDF format download High resolution complete Circuit Diagram
Download Circuit Diagram
Thank you for choosing fixya
Good Luck
Aug 21, 2009 | Televison & Video
Nikon FA will not advance. Meter will not give reading.
the capacitor is bad or the circut has a fault somewhere. You will need to take it to a camera tech or just use it in the manual moide only
Jan 14, 2009 | Nikon FA 35mm SLR Camera
Remote control code for watson tv
I have a watson hz 9205 and I need the codes for a LG televison
Nov 21, 2008 | Directed 434MHZ Remote Control
Edirol Fa66 Problem
I bought the FA-66 because I use Cakewalk Sonar and they sell this interface on the Cakewalk site with thier name on it. I've had nothing but problems with this unit as described above. I've tried it on two different computer and it does not work on either. I also use an RME Fireface 800 on both these machines, same set up and it works flawlessly. Drop the Edirol/Roland FA-66 and try something else like an RME card or something. That would be my suggestion. It's a shame Cakewalk promots this piece of garbage. I've tried Edirol/Roland technical support and the guy just kept saying the sound card works fine, like it was just my problem.
Jan 06, 2008 | Edirol FA-66 (EDIFA66) Audio Input
Televison & Video Logo
465 people viewed this question
Top Televison & Video Experts
Electro Med Services...
