My tv is locked it is a mitsubishi 305-301 i my daughter is 7 and she locked it. please help
  • 149 Answers
This may work for you if not e-mailme @ networks@q.com uoy need original remote control (select no lock channel press press mode untill lock display press 9 and QD same time boht good luck....
Posted on Apr 09, 2008
How do I in lock my daughters TV its a bauhn 19 inch LCD/DVD,when I push the menu button on the TV it comes up with,keypad locked please help
Excuse me buy you sound rather confused. You want to LOCK a TV? Has it some option on menu to lock with password? Please EXPLAIN YOU PROBLEM AND BE SPECIFIC
Jul 10, 2015 | Computers & Internet
Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 29, 2010 | Mitsubishi WS-48315 48" Rear Projection...
Reset parental control password
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
I hope that helps.
Sep 26, 2009 | Quasar SP-2722 27" TV
Cannot unblock v chip locked programs
It should be your owners manual or try Mitsubishi USA.com
Aug 26, 2009 | Mitsubishi LDT461V 46 in. LCD TV
Mitsubishi tv
These steps are actually for a Mitsubishi Projection HDTV, but I think they may work for a Mitsubishi LCD HDTV too.
I hope that helps.
Jun 23, 2009 | Mitsubishi WD-65C8 65 in. LCD HDTV
Mitsubishi ED-52631 does not turn on
Hello Getoxygen,
This sounds like a DM problem. To repair this you will have to replace 4 or 7 capacitors (1000uf 35v).
Here are the instructions. Depending on your set this may differ a bit, but the central theme is getting the DM free to be worked on.
This was taken from a TV repair site used by TV technicians.
STEP 1) The DM Module loose. But itcan't be rotate out because of the upper plastic guide.
STEP2) How the DM Module is rotated out of the TV case. Allow thewires
entering the DM Module to be an axis point of the rotation.That way they barely move and don't get snagged or stretched.
STEP3) The DM Module out and the side cover of the metal housing removed.
STEP 4) My setup to do the soldering work.
STEP5) Up Close of the daughter board and the seven capacitors on
MitsWS-55859.
STEP 6) The daughter board unscrewed and flippedover where you will be soldering.
STEP 7) The UpperPlastic Guide that must be removed to rotate the DM Module out of theTV set.
STEP 8) Get this wooden horizontal shelf out (4screws) and getting the upper plastic guide out becomes easy.
STEP9) Helpful Hint about the wooden shelf and the platic guide that bothneed to be removed.
I hope this helps
Thank you,
Nov 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
V-chip
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "5", "7", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIALIZE."
4. Press "ENTER
You can also push the 9 and QV buttons to temporary by pass v-chip.
Nov 04, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Parental control/lock on Mitsubishi WS-55613
I hope that helps.
Aug 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi parental control reset for tv model vs-5061
I hope that helps.
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
