Having a no signal on my screen from my sat. receiver- directv
dauphine
  • 207 Answers
SOURCE: unable to find code for Sat receiver
http://www.urc.philips.com/
Posted on Apr 10, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
b_stro804
  • 68 Answers
SOURCE: toshiba dr-2 and directv hd sat rcvr hr22
Check the manual to see if there is an automatic code search feature for your Toshiba. It may be easier to program your directv remote to operate your toshiba. You may not get the full use from either remote, but its worth a shot
Posted on Jan 08, 2009
paulrelliott
  • 69 Answers
SOURCE: I have a motor home,the signal strenth on my sat.
Check the lead's between the sat box & tv are good if the tv is giving the no signal message, if not the sat box may be defective, but try checking all the lead's even up to the dish.
also I dont know where you are in the world but you could be pointing at the wrong satellite, there are lot's up there!
Hope this help's !
Posted on Sep 23, 2009
SOURCE: thomson dsi 4101:Have been given this receiver,
stick it up your but!
Posted on Dec 28, 2009
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Is there a code for directv that will work my Viore tv
Try to go in receiver menu by using your sat menu go to setup remote then follow instructions on screen goods luck
Jan 13, 2012 | Directv Televison & Video
R10 receiver
one wire should be going out the wall or through the wall, that wire goes to (sat in) port. If your other wire goes to the tv, that one goes to the (out to tv) port.
Jan 22, 2009 | RCA R10 DIRECTV Receiver/DVR with TiVo
No signal
if you have switched them around and u still have the same problem from the receiver, them the box is bad. call directv and let them know. they will either send u a new one or send a tech out to replace the bad one
Sep 19, 2008 | Directv D10 DTV Receiver
No sat-go reception
I believe there is a special package that you must have to use this item. Contact directv sales.
Sep 13, 2008 | Directv Sat-Go Portable Satellite TV...
Will not boot- Sits at searching for sat forever and does not get past this point
I had this same issue recently. Unplug the receiver, for approx 30 seconds and after you plug it back in, it should receive the signal and boot up when you turn it on.
Mar 19, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Viewsat 2000 ultra problem
unplug the receiver for 30 secs. also try pulling out the card. then try again.
wg
Feb 16, 2008 | Samsung SIR-S300W DirecTV DTV Receiver
Second DirecTv box unable to locate a signal
it is multi sat multi sat compatable!My opinion is buy a powerd multi switch you can getem at radio shack or from a sat dealer that will clear p your prolem i belive also check all your rg6 coax ends u may have a a bad splice or a fraid shiel wich will make your reciever do the same thing but hope you can fix it
Goodluck
Please rate
Dec 11, 2007 | Televison & Video
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Sep 25, 2007 | RCA DRD485RG DirecTV DTV Receiver
DIrectv Sat internal box.
You can try eliminating whethor or not the receiver is actually the problem by moving it to another TV and seeing if it works on one that isn't having any problems. Or moving a working receiver onto the TV to see if it will pick up signal with a working receiver. If you don't have any receivers in your house working, then odds are something needs to be serviced outside your home, like the Dish and/or LNB.
Did DirecTV actually come out to the home and troubleshoot at the site? If not, they would have no way of knowing if it's the TV or Satellite that's causing the issue.
Aug 09, 2007 | RCA F38310 38" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
