Question about Dual XDMR-7700 CD Player
Volume only goes up with faceplate open
When the face plate is open the volume turns up no matter which way you turn the volume knob, the problem is the same for adjusting any of the settings using the same knob. When closed it works perfectly, also the remote only works when closed but not open. Any help would be great thanks.
  • 1 more comment
  • Anonymous Jun 01, 2008
    dual cd 770 remote will not work when face is open. no controls work when face plate is open
  • Anonymous Jun 10, 2008
    I have the same problem. When I turn the volume down, it goes up?
    I have the same problem. I also do not have the remote. I tries resetting the system, but did not work.
    Genius:
  • Dual Master
  • 1,550 Answers
Tienes un problema con los push buttons en la carita uno de ellos esta danado.Resetea tu estereo en la carita tiene un mini orificio con un boton para resetearlo intenta esto,suerte.
Posted on Apr 09, 2008
Faceplate display only functions when you touch a knob or button
THE FACEPLATE HAS LIKE SOME PINS WHERE IT MAKES CONTACT THE FACE PLATE WITH THE STEREO BODY WITH A COTTON AND SOME ALCOHOL CLEAN THE CONECTOR THE ONES THAT ARE IN THE STEREO BODY AND THE FACE PLATE BUT WHEN YOU MAKE IT MAKE SURE THE CAR OR FACE ITS TURN OFF
Nov 02, 2013 | Alpine CDA-9831 CD Player
On a audiovox vm9312 I lost remote and can't turn
The VM9312 has a volume knob on the unit's faceplate. Just rotate the knob on the left (a little below the optical disc D slot) clockwise to increase the volume. Turn it the opposite way to lower the volume. (If you have the knob set to the maximum volume and then lowered the volume with the remote, you may need to reset the unit; see below.) If you push in and release on this button, you press Enter or confirm a setting when you are in any audio settings menu.
If the volume control isn't working, check if the mute is on. Press once to toggle the Mute. The mute button is just below and near the right side of the optical drive slot.
If you still can't change the volume, check if you have the wiring correct and no shorted wires. Look for damage at the speakers (or evidence of mice chewing on the wires). Also check your audio balance. See the manual page 12 here: http://www.voxxintlcorp.com/docs/common/VM9312/VM9312_OM.pdf . You may also want to try a system reset. (Press and hold the reset button for a few seconds by using the tip of a ballpoint pen in the little opening at the lower right hand side of the faceplate.)
I hope this helps.
May 24, 2013 | Car Audio & Video
Pioneer deh p80mp
parts.com but you can fix it with jbweld. just remove the plastic with metal piece that is stuck to the volume button ON the faceplate and place it back in the center of the volume button knob. mix both pastes together and apply it aroun the plastic center of the knob. Ps don't add inside the hole where it attaches to the face plate. just follow the directions behind the jbweld pack.
Sep 08, 2009 | Pioneer DEH-P80MP CD Player
Buttons locked
if the face is remove able change the face your problem like that is cause by face plate
Jun 24, 2009 | Pioneer DEH-P6700MP CD Player
Volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Dec 23, 2008 | Pioneer VSX-D409
Annoying blue light on volume control.. can it be turned off?
The face plate is easy to take apart, just remove the face plate off the head unit and take the hex screws out and put a piece of tape over the bulb on the system board. Then put it back together again.
Nov 03, 2008 | Kenwood KDC-MP238 CD Player
Uncontrolling!!
You've either got a short from faulty manufacturing or possibly from moisture entering your unit. Or the wiring may be faulty, if you know how take the unit out and examine the wiring; make sure the wires are all taped with electrical tape and that no bare wires exposed or touching. If everything looks ok then you might as well just exercise the warranty. They come with a 1 year warranty from Dual.
May 20, 2008 | Dual XD-7500 CD Player
How do I remove the face plate from my C330 GPS?
The face plate is removed by inserting your fingernail under the silver plate in the center top of faceplate.It pulls out quite easily. Rob
Sep 17, 2007 | Garmin StreetPilot C330 GPS Receiver
Bad face plate!
It may be the flexible connector link connecting to the drop down faceplate.
Aug 14, 2007 | Dual XDMR-7700 CD Player
Dual XDMR-7700 CD Player Logo
166 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
