Question about Garmin nuvi 265 Car GPS Receiver
Topo maps have just got topo maps on sim card put it in and not noticed any difference what have i done wrong .is there a special way of loading these sim cards help please regardsPeter
  • 67 Answers
Hi peter, firstly the only difference you would notice with topo maps is that the unit will now display contour lines and they will only be visible when you are viewing the map not when you are in the navigation mode.
the contour lines are brown lines on the map that represent different heights above sea level.
Posted on Jun 03, 2010
I have purchased zumo 595lm and have put topo mini sd card loaded with topo maps it has wiped out the origanal maps can i reinstall the origalmaps to it
Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to register it, as well as provide any current updates. Install any maps from this process on the device itself.
Jul 03, 2016 | Garmin zumo 595LM 5" GPS with Built-In...
I cannot locate topo maps loaded via sd card
If you have the TOPO maps loaded to an SD card and the card is inserted all you should have to do is go to Tools > Settings > Map > Info in this menu you will find your map sets if you see TOPO make sure it is activated if not you may need to re install them to the SD.
Hope this helps!
Feb 12, 2011 | Garmin nuvi 1490T GPS Receiver
Can i install my topo canada map on my etrex legend or do i have to remove basemap first and then load topo
No you can just load the topo and have the etrex directed to the card that you have installed and deactivate the pre-installed map
Mar 04, 2010 | Garmin eTrex Legend GPS Receiver
Can't view downloaded sections from Garmin Topo
In Map Setup page, scroll over to blue 'ball' icon (second from right), press lower left button on side of GPS unit, use Thumb switch to scroll down to "Show None", click Thumb switch in. All maps will disappear. Press lower left button on side of GPS unit again, scroll down to "Show Topo.....", click Thumb switch in. Your Topo maps should now show onscreen.
The reason your Topo map might not have shown is because, if you leave the Navigator map showing, and then just press "Show Topo", the layer showing Topo will still be under the Navigator map. This is why I always tell it to show none, and then load whatever map I need to see onto a bare screen.
If this solved your problem, please come back and rate our answer as this assists others. Thank you.
Feb 04, 2010 | Garmin eTrex Legend GPS Receiver
Garmiin nuvi gps,
The device uses SD cards actually. They will not however work with TOPO maps or Bluechart. They are primarily for loading media or city street maps for other country's.
Jan 14, 2009 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
GPS position is offset from map location
This could be because your datum and your posistion format. Under your menu go to setup, then units and make sure you have the correct info set in there for your area. NAD27 Canada would be the one you are looking for. Give that a try and see if it works. If it is still off, consult the manuals that came with your topo and see if it says what datum it uses.
Nov 15, 2008 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Connection issues
yeah , i am with garmin 196, and usb to rs232 cable and instaled driver, but it wont connect ..... anybody help ?
Aug 30, 2008 | Garmin GPSMAP 60CS GPS Receiver
Topo maps a mess of meaningless lines
Sorry for late reply. You need to select an area on your topo map prior to downloading it. For example, if you plan to go to Algonquin Bice Lake (access point 4), then you need to select the map around the area (starting from) Kearney upto the Magnetawan Lake and beyond. Mark waypoints from the put-in to the campsite on Bice Lake (best to compare of the topo and Algonquin canoeing map). Then you can click Transfer, click Send to Device (GPS 76cs should appear) to download it. On the GPS, enter the Find Waypoint button and you should be able to see those waypoints. Good luck for your next trip.
Aug 03, 2008 | Garmin GPS 76 GPS Receiver
530 hcx
You need to select all the segments at the same time and then transfer to the GPSr. Do not send one set, then another as the second set will overwrite the first set.
Feb 20, 2008 | Garmin Rino 530 GPS Receiver
Garmin nuvi 265 Car GPS Receiver Logo
171 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
