Question about OTC (OTC6020) Ford Camshaft Positioning Tool
My car dies after driving the car for more than 5 km, the machanic say's its the Cam Shaft ? What are the symptoms of a faulty Camshaft ?
  • 391 Answers
The car doesn't run at all or runs with reduced power but this is usually associated with hot rod motors with a high lift camshaft that has "gone flat". I think you should ask a second mechanic about your car.
Posted on Jun 03, 2010
What is the function of the cam sensor on the 325 E36 bmw. can the car start with a faulty camshaft sensor. If so what will the car do
as the cam shaft position sensor works in combination with the crank shaft position sensor to tell the ECM where the piston is for the correct firing and timing
it would be unreasonable to consider that the engine would function with a faulty unit
basically if the cam shaft sensor is not operational then the engine will not start
May 21, 2015 | Cars & Trucks
Dohc focus overheating
You need to take off the timing belt (or chain) cover and see why the one camshaft is not turning. Maybe the belt for that cam broke or the cam has seized from a bad cam bearing. One camshaft should be for the intake valves, the other cam is for the exhaust valves.
Feb 13, 2014 | Mazda Cars & Trucks
Code p0017p0300
P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
Symptoms of a P0017 will or may include: Malfunction Indicator Lamp (MIL) illumination The engine may run but with reduced performance The engine may crank but not start The engine may exhibit a rattle near the harmonic balancer indicating the tone ring is damaged The engine may start and run, but poorly Causes Causes may include: Timing chain stretched, or timing belt skipped a tooth due to wear Misalignment of timing belt/chain Tone ring on crankshaft slipped/broken Tone ring on camshaft slipped/broken Bad crank sensor Bad cam sensor Damaged wiring to crank/cam sensor Timing belt/chain tensioner damaged An improperly torqued crankshaft balancer A mis-built or mis-timed engine A loose or missing crankshaft balancer bolt The CMP actuator solenoid stuck open The CMP actuator stuck in a position other than 0 degrees
P0300 Random/Multiple Cylinder Misfire Detected
Symptoms may include: the engine may be harder to start the engine may stumble / stumble, and/or hesitate other symptoms may also be present Causes A code P0300 may mean that one or more of the following has happened: Faulty spark plugs or wires Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector(s) Burned exhaust valve Faulty catalytic converter(s) Stuck/blocked EGR valve / passages Faulty camshaft position sensor Defective computer
Oct 15, 2013 | GMC Envoy Cars & Trucks
99 GMC suburban 5.7l P1345 wont start/misfire
The primary intent of this code is to detect slipped camshaft timing. Have you checked the camshaft timing? Your symptoms indicate you are a tooth off.
May 24, 2017 | 1999 GMC Suburban
Dealer said camshaft may need to be replace, did tune up on my 2003 trailblazer and sent me on my way. he said to drive for a couple weeks and see how it is, car died completely on highway a week later....
camshaft or the camshaft sensor? there is 2 diffenrent things if is the camshaft what is your car doing? your car will die if the camsensor is bad too. please make sure what is it. Thanks
Nov 08, 2011 | 2003 Chevrolet TrailBlazer
What is a cam crank sensor on 2004 Audi A4
The "cam crank" sensor is the "reader" for position and speed of the camshaft. This sensor send informations to Engine Control Unit about camshaft position and speed. If the sensor is faulty engine stops!
Oct 23, 2009 | 2004 Audi A4
Hello. Could you please advise me what the camshaft torque tightening specs are for a 1993 SEAT IBIZA . Thank you
CAM SHAFT BEARING CAPS 15 FT LBS. DRIVE SPROCKET BOLT 58 FT LBS. CAMSHAFT END PLAY IS 0.006 in. WARNING THIS IS THE 2.8L ENGINE WHEN TORQUEING CAM SHAFT BEARING CAPS YOU HAVE TO TIGHTEN THE BOLTS 2 TURNS AT A TIME IN A DIAGONAL PATTERN TO DRAW THE CAMSHAFT DOWN AGAINST THE VALVE SPRING.
Sep 29, 2009 | 2002 Volkswagen Golf
1991 vw golf gti- RPM stop working!
judging by the amount of km it has done i would say the rpm drive is faulty, this measures the amount of rotation in the camshaft and shows the "revolutions per minute". when this goes faulty it stops the read out on the dial, so you want to be looking for a device that measures the speed that the engine is turning, if you have, replace it and it should solve the problem
Nov 20, 2008 | 1988 Volkswagen GTI
OTC (OTC6020) Ford Camshaft Positioning Tool Logo
43 people viewed this question
Top OTC Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an OTC Measuring Tool and Sensor Expert? Answer questions, earn points and help others
