Question about HP Compaq ProLiant DL380 G4 Server
Hp dl380 G3 no display on screen. - HP Compaq ProLiant DL380 G4 Server
  • HP Master
  • 4,924 Answers
If you mean that just shows a bue screen and no task bar or desktop ..this is probably from a virus attack that cause it ..Try to press ctrl+alt+del this should show the task manager and in the task manager run a new tas ...and lunch the windows explorer again ..
or just run from task manager the system restore..and try to restore it to an earlier date that worked..To do that pres those like I said ..and than in the task manager on screen choose file and new task (run) and type system restore..and hit enter ..ths should run it ...choose the date that you know it worked and run it ..If it do not restore you have to reinstall or ..to use it for the moment find the desktop address and add it in the start-up for that run MSconfig and press enter ..in the start menu ..choose normal ..and enter ..and choose restart ..it should get along well again..
Posted on Jun 03, 2010
4 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: Please help, I have a
hmm probably the boot from cd is not initiate ..go to bios settings and restore optimal factory defaults..after that rearrange the boot device order to boot first from cd..after that save changes and reboot.. ....make a boot-able cd with server 2003 ...(it is enough cause it will update to the latest if it is genuine ..) and when its done insert and reboot...it will prompt you to press any key to boot from cd ..
for most of them pressing the F8 on during the boot will get you directly to the boot menu ..and selecting the device here will bypass the bios settings ..but not all supports this ..or have the same key for boot menu ..usually it is written on the screed near the key for bios..
anyway ..I will link a fully described step by step installation ...be careful cause there are steps that are not a must to choice..but in general it almost like a Xp installation ..
the thing that keeps you in this moment is the boot device order..(probably the boot from cd is disabled in the bios)so ..go there and check ..and thats all..
here is the link to have something to consult with on the run ..
http://www.petri.co.il/install_windows_2003.htm
Posted on Mar 30, 2010
Testimonial: "Great advise...my CD was bad. "
drifterK
  • 4924 Answers
SOURCE: Hp compaq prolaint dl380 g4
if you mean that just shows a bue screen and no task bar or desktop ..this is probably from a virus attack that cause it ..Try to press ctrl+alt+del this should show the task manager and in the task manager run a new tas ...and lunch the windows explorer again ..
  • 24 Answers
SOURCE: HP DL380 no display on
does the server power on?
When i purchased my first DL380 i had a simular issue, as it turns out the datacenter i had purchased the server from, had installed a ILO replica type card. if you have the same card installed (it will have a ethernet port, power port, and video port) , this can be causing the issue, also, the card will be located in the PCI-X Slot.
Posted on Jun 14, 2010
How do i hook up speakers to hp compaq
The computer will have a small speaker jack with a green ring around it. Plug it in there and you can probably control it's settings on your task bar on your desktop. If it's not green it will be labled.
May 08, 2012 | HEWLETT-PACKARD Hewlett Packard HP /...
HP DL380 no display on screen
Jun 03, 2010 | HP Compaq ProLiant DL380 G4 Server
I have instaled a new Vista Win and my sound card doesnt work now
does the compaq or hp.com site offer any drivers for your model of computer? Should be there or at driverguide.com
Jul 07, 2009 | HP Compaq ProLiant DL380 G3 Server
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Software Checking for Particular DL380 Processor
If your proc speed is 2.8, then what is the problem? The min speed required is 2.4 GHz right?
Anyways you may try overclocing the processor, however at your own risk as this may cause damage to the server.
http://www.xbitlabs.com/articles/cpu/display/oc-guide.html
http://www.pcguide.com/opt/oc/risksRisksCPU-c.html
Mar 30, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
869 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
