Question about Sony Cyber-shot DSC-W50 Digital Camera
Camera Will No Longer Power On
A few days ago I accidentally dropped my camera while trying to put it in my bag and now my camera is completely dead. It won't power on at all. My battery was fully charged and this is the first time I've ever dropped my camera.
Is there a solution to this or should I just bite the bullet and get a new camera?
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jun 03, 2010
Canon digital camera no power
Power issues are common in anything electronic, including digital cameras.
A digital camera can fail to power up for a number of reasons, but fortunately, they're often related to the batteries, making them minor in nature.
If your digital camera won't turn on, check several things to diagnose the problem.
Battery Life
It is common to try to turn on your digital camera, only to see that it will not power up. A highly likely cause of this issue is the power in the battery or batteries. If you've used the batteries for an extended period of time, mistakenly left the camera on or are using old batteries, they may simply be dead. Remove the batteries from your digital camera and test them in another electronic device, such as a remote control. If the second device won't turn on, the batteries may need to be replaced or recharged. b> Battery Position b> Though it sounds like a mistake that is too simple to make, it's easy to insert the batteries incorrectly into a digital camera, especially if it's new and you're unfamiliar with it. When the batteries are put in backward, the digital camera will not power up, leading you to assume there may be a graver problem. If the camera will not turn on, open the battery compartment and verify that they're in correctly. If not, rotate them appropriately, close the cover and try to power up the camera. b> Lens Track Problem b> Depending on the camera bag you use, the camera may occasionally and accidentally get turned on while it's in the bag. When this happens, the lens may begin to extend outward from the camera, but get blocked by the camera bag. All this can happen completely unbeknownst to you, which can lead to the camera not turning on the next time you need it. In some cases, the lens can get knocked off its track, which can result in your camera's power light illuminating once the camera is turned on, but the lens not emerging from the camera body. In more severe cases, the lens' repeated attempts to emerge while stuck in your camera bag can burn out the small motor that operates the lens. When this is the case, take your camera to a repair shop and have a technician look at, and fix, the problem. b> Defective b> Although not likely, there's always a chance that when you buy a new digital camera and load it with fresh batteries, it won't turn on. If this is the case, the camera may be defective in some way. Because new cameras are covered under warranty at many shops, take the camera back to the shop and explain the issue to a technician. Hope it helps.
Jan 24, 2013 | Canon IXUS Cameras
I Dropped My Camera In The Water for a Few Seconds And I Tried To Turn it On And It Doesn't Work Its a Nixon Touch Camera
Hi, Sounds like you may have fried the camera by trying to turn it on, your best bet would be to put the camera in a bag of rice for a few days to see if that'll dry it out, if after that it won't work still the camera's unfortunately dead.
Aug 29, 2011 | Cameras
SD1100 got wet,now LCD sceen is completely black when power is on, it is not working, how much to get fixedor new one is cheaper than get fixed?
Probably not worth the time and money to fix it. One last try, you can take the battery out and put both camera and battery into a bag of dry rice (uncooked of course :) make sure it's completely covered and leave for a few days. Sometime, this will completely absorb the moisture in gadgets that got wet and it might work again. Since you tried turning it on after it got wet, it might not work b/c something may have shorted out.
Mar 01, 2011 | Canon PowerShot SD1100 IS Digital Camera
After taking the camera into the water, it won't stay on.
Remove the battery and then immerse both the camera and the phone into a pound of dry uncooked rice for at least three days. The dry rice will **** all of the moisture out. After three days put in the battery and try it. If it works. problem solved. If not, remove the battery and stick it all back into the rice for a few more days.
Nov 18, 2009 | Olympus Stylus 770 SW Digital Camera
Cemara is dead
This may sound odd, but I read this somewhere. Put the camera in a bag of rice overnight. Rice is a good dehumidifier. Take it out the next day and turn it on.
Mar 13, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Polaroid i533 won't power on
I havent even had mine for a year yet! BOO HOO! I really need a camera cause I have a baby
Mar 01, 2008 | Polaroid I533P Digital Camera
The lens on my camera won't retract.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
The lcd screen on my polaroid i533 digital camera went out
your screen is broken, some one must have accidentally put pressure on just the screen. The smae thing happened to my screen now i am looking to buy a new screen
Oct 27, 2007 | Polaroid I533P Digital Camera
Camera that went for a dip.
I would have immediately taken out the batteries.  (perhaps a tip for next time.)
Unfortunately your camera may be dead.  But with small electronics like that , you can sometimes get lucky if you disassemble them a bit so air can pass through them freely, and leave them alone without a power source for awhile.  I have revived 4 cell phones that way..In 2 cases there were side effects... 1 could no longer charge a battery and the other could not get a cellular signal. Worth a try.
Hope this helps
Oct 12, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
161 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
