HP A867C WOn't start/boot
I had a power outtage in my place the other day and wasn't home to unplug my appliances. I came back and tried to turn on my computer and it wouldn't start. I noticed the green light in the back blinking and I could hear it ticking as well. I unplugged the tower and let it sit for 30 minutes or so. Still not working. I opened the side panel and unplugged the ATX cable from the motherboard and waited for 3 minutes. I plugged the power cord back in without reattaching the ATX cord. The green light in the back stopped blinking and stayed solid. None of the fans turned on, but I plugged the ATX cord back into the motherboard only to find that the solid green light was blinking and ticking once more. I unplugged the ATX cord again and the light turned solid. The tower still wouldn't turn on and none of the fans turned on. I took a closer look at the components and found that I have two capacitors that are bulging slightly. I am at a loss of what to do. How will i know if there is something wrong with the motherboard or the power supply? Will two bad capacitors effect the entire system like that? I have important files on the tower and haven't gotten the chance to buy an external back up system and am currently low on funds. Anyone know what I can do?
  • Computers & ... Master
  • 5,660 Answers
1) Take the SATA harddrive out, install it into a SATA external enclosure. The external enclosure has a USB cable that you plug into the USB port of a working computer. You can retrieve your data this way.
One example of a decent economical SATA 3.5 inch external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
2) Which Capacitors are bad?
Only takes One bad capacitor to drop the computer to it's knees, if it's a capacitor in the motherboard Voltage Regulator Circuit.
Part of what the motherboard Voltage Regulator Circuit does is regulate voltage for the Processor.
The Asus PTDGD1-LA motherboard, is used in the HP Pavilion a867c desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00196251&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=448709&lang=en
(HP/Compaq name is Grouper-UL8E)
I would like you to scroll down the page, and look at the motherboard photo under the motherboard illustration.
Which two capacitors is it?
(You can save the motherboard photo to your My Pictures folder, and enlarge it for better clarity.
Put your mouse cursor directly on the motherboard photo, and Right-click.
In the drop down list Left-click on - Save Image As
In the Save Image window you will see - File name: at the bottom.
In the box to the right of File name: will be the file number -
c00208573
If you have a lot of photos in your My Pictures folder, looking for the file name - c00208573 may lead to difficulty.
Should you wish to make finding the file easier, you may wish to do this.
Put your mouse cursor after the 3 in c00208573.
Left-click twice.
Make one space with your spacebar.
Type - HP Pavilion a867c
Now go below, and Left-click on - Save.
Go to your My Pictures folder, and Double-click on the file name.
At the bottom of the window you will see a Zoom In icon for enlarging the motherboard photo. Looks like a magnifying glass with a + sign in it)
I'm hoping your bad capacitor reference, isn't regarding the Power Supply. (Actually I kind of hope it is. Read on)
Capacitors slowly build up a charge, and release it all at once.
There are Electrolytic Capacitors used to Filter the incoming AC electricity, (Input Stage), and the outgoing DC electricity the Power Supply has converted. (Output Stage)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Electrolytic Capacitors can store a charge for a Long time, after power has been removed from them.
Weeks, Months, and sometimes over a year.
If your finger/s should touch both leads coming out of an Electrolytic Capacitor, the charge could be released to you!
If your finger/s complete a circuit that one, or more Electrolytic Capacitors are in, the charge could be released to you!
Result can be a BAD shock to FATAL!
(Especially the capacitors used in the Input Stage!)
On the other hand, if it is two Electrolytic Capacitors that are bad in the Power Supply, you may be lucky, and just have to replace the Power supply to get your computer working again.
(Above ALL, I want you to be SAFE!)
Most of the capacitors used on a motherboard, are in the motherboard Voltage Regulator Circuit.
Part of what the motherboard Voltage Regulator Circuit does, is to regulate Voltage for the Processor.
The Processor must have a Steady, 'Clean', supply of voltage, and it must be within a specified range.
Too much, or too little, and the Processor will not turn on, or stay on.
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-The-Motherboard-Voltage-Regulator-Circuit/616
Looking at the Asus PTGD1-LA motherboard, it looks like Solid Capacitors are used around the Processor socket.
To my knowledge they do not bulge, they just pop open.
These capacitors are part of the motherboard Voltage Regulator Circuit.
However there are other capacitors that are not in close proximity to the Processor socket, and may be Electrolytic Capacitors.
IF, it is Electrolytic Capacitors, AND IF, they are part of the motherboard Voltage Regulator Circuit, having just two of them go bad can make it so the Processor will not turn on.
They are in a Series circuit.
Replacing the two bad capacitors may, or may Not, be all that is needed. There may be more bad capacitors that are not showing visual signs of failure, or that you haven't spotted yet.
The damage could also have gone further.
Best option is to simply replace the motherboard.
Do I have a concise, clear solution for you?
No sir.
Reasoning?
If this computer were in my shop, and I spotted two bad capacitors on the motherboard, I would start with replacing the motherboard.
(Actually I would try replacing the capacitors, and see what happens. Computer geek, lol!)
I would also test the power supply.
I happen to have a few spare Power Supply's around, so I would just use a KNOWN to be good, Compatible power supply for a test unit.
You can test the Power Supply with an economical multimeter. Doesn't take a Fluke quality multimeter for this diagnosis. You can use a $5 multimeter.
You can also use a power supply tester.
Continued in an additional Comment.
Posted on Jun 03, 2010
  • 553 Answers
Your bulging capacitors might indicate you were hit by a voltage surge but replacing them is not likely to solve the problem.
You can get a power supply tester (approximately $20) at most computer stores and sometimes at office supply stores. These tester vary as to how much information they give you but all that I've seen will tell you if your power supply has a problem. Try to get one that test your power plugs for your drives as well.
Testing the Motherboard is a much more complicated situation. It requires special test equipment that is rather expensive. Most shops either send them to a testing facility or just swap out parts to determine the problem.
You can pick up an USB drive adapter ($20-$40) at the same places you can get the tester, this will allow you to take the drives out of your computer and access them from any computer with the right USB port, most recent computers are USB 2.0 which is what you'll need. You may need to buy a wall transformer depending on the model adapter you get. Make sure to set the drives flat on a non-conductive surface.
There is a chance that the drives may have been damaged as well. If this is the case depending on the value of the data you can have the data retrieve by the drive manufacture but it's not inexpensive.
  • 600 Answers
The capacitors you are referring to. is located at the power supply or the motherboard, if youre referring at the motherboards capacito, your motherboard is toast, and the only solution is to buy another motherboard, hopefully the capacitor you are referring to is at the atx. and the only thing you would replace is the atx power supply. i guess your data is safe, and you can check that by slaving your hdd to other pc.
  • rhuns1 Dec 12, 2010
    I had exactly the same thing happen to my a867c. I observed two bulged caps as well - one on either side of the dimm sockets. Having just repaired a magnavox plasma with the same issues, I replaced my motherboard ... sadly no luck, the power supply light is still blinking. I just ordered a new power supply, and if that isnt the issue, the only thing left is the processor ... total cost to repair will be motherboard=35$, power supply=30$, processor=30$ ...i am going to check my power switch on the front, I'm guessing it's a momentary type. Any comments on my issue are greatly welcome ... if I find that it was the processor, I think I'll replace the caps on the first MB just for practice .....
Toyota Echo Won't Start
check starting system. as you said, you were be able to start when it push.
and if you notice when ignition is on the engine not cranking, starter is the sure problem.
May 27, 2013 | Cars & Trucks
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
I have an hp m8425f and the tower won't turn on,
Remove the Power Cord, then press and hold the power button for 30 seconds. After 30 seconds, plug the cord back in and press the power button. If it works, you had a Static Charge Buildup that had to be released.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If the above two steps fail, pull the main power plug that comes out of the power supply and plugs into the motherboard. The end that plugs into the motherboard is probably about two inches long, Grab the release latch on it and press it while pulling up to unplug it. Wait 30 seconds then plug it back into the motherboard. Push it back in firmly.
Try turning on the system.
Apr 04, 2012 | HP Computers & Internet
Computer ramdomly turns off
Instead of unplugging everything, only unplug 1/2 of the things. If it still won't start, unplug 1/2 of the remaining things (noting which ones they are). If it restarts then, it was one of the last set of things you removed that is the problem, so keep eliminating possibilities in this fashion this until you can determine which component it was. If it turns out to be the power cord, it could be a problem with the power supply.
Mar 02, 2012 | HP Computers & Internet
HP Pavilion a867c turns on, then right back off. Power button stays lit but there is nothing but a flashing cursor on the screen.
CHECK THE CABLE SATA/PATA WHICH EVER INSTALL. >THEN GO BIOS > F-10> SET THE BIOS PIORITY >TRY TO BOOT 1ST FROM CD /DVD
2ND HDD
SAVE IT
OR FIT ALL CABLE TIGHTLY .
STILL CAN NOT RUN ,THINK IT HAS EFFECTED BY VIRUS.
SO DELETE PARTITION ALL THE DRIVE AND CREATE PARTITION AND INSTALL IT AGAIN .
HOPE IT WILL SOLVE YOUR PROBLEM
SHIBUDA
Nov 24, 2010 | HP Computers & Internet
My GE GDL20KCSABS has been making odd rhythmic clicking noises for a long while. We had a power failure and It started working intermittently. The freezer worked and the fridge didn't; now neither are...
Hi Rob. I need to ask if you have done the unplug it for 30 minutes routine. What happens when there is a brief power outtage is the coolant system is not stabilized so the internal compressor temps and pressures are very high. As a result the compressor tries to start with those internal high pressure and the only thing that happens is the Klixon thermal overload will cycle about every 4 - 5 minutes but the compressor will not start. As a result of that cycling and the compressor not starting the interanl compressor heat remains very high and self heats in the process. Hence I recommend you unplug the unit and possible place a fan directed toward the bottom of the unit to assist in cooling it down. After 30 minutes plug the unit back in and see if the compressor starts.
Just a note about appliances damaged by power.... you may want to contact your local unility. There is a good chance they can be held liable for the damages as a result of that outtage especially if there was a high voltage surge as a result of power restoration or initial power failure.
Your main circuit board is item 801 of this link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5219931&diagram_id=25943525#d25943525
and appears to be on the back of the unit. Access panel for the main board item 415 must be removed to change the main board.
Just a note item 621 on the side of the evaporator is a thermal fuse. It can cause this problem also. It is a very remote possibility though.
Thanks for choosing FixYa.
Kelly
Aug 29, 2010 | Microwave Ovens
My MP600 is not turning on after my home had a power outtage. The power in my home is now on and everything else turns on except my MP600 printer.What doo i need to do to turn it back on?
Unplug the power cord for a couple minutes and when you power on again, hold the power button for a few seconds until you hear a beep. There may have been a surge with the outage that has hurt the internal power supply requiring a shop repair if the power doesn't return.
Feb 22, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Apr 25, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
624 people viewed this question
David Payne
David Payne
