Question about Kyocera Copystar CS-1620 Black and White Copier
The photocopy makes a noise as an airplane when it's functioning.
    President:
  • 3,085 Answers
The bearings in the Laser Unit have gone bad. You need a new Laser Scanner Unit
Posted on Jun 04, 2010
After installing Windows 10, why won't airplane mode turn off and wifi is limited?
How to turn on or off Airplane Mode in Windows 10
Option 1:
1. Open Action Center (Windows Key + A)
2. Click/tap on the Airplane mode quick action button to toggle on or off.
Option 2:
1. Click/tap on the network icon in the taskbar notification area.
2. Click/tap on the Airplane mode button to toggle on or off.
Option 3:
1. Open Settings, and click/tap on the Network & Internet icon.
2. Click/tap on Airplane mode on the left side, and turn on or off Airplane mode on the right side.
3. When finished, you can close Settings if you like.
Airplane mode issues can be of different ways. One might be unable to turn off the airplane mode as its toggle indicates the function is unavailable for the time being. Few users might not be able to activate the wireless connections as they are not willingly glued to the Airplane mode. And there are situations where Airplane Mode turns on automatically refusing other wireless devices to perform correctly. So, we provide you different solutions to try for the above mentioned Airplane Mode issues. So, let us head towards the main topic and see How to Fix Airplane Mode Issues in Windows 10.
How to Fix Airplane mode not turning off in Windows 10:
Solution 1: Change Network Adapter Properties
1. search for Device Manager in Start Menu or Cortana and open it.
2. Make your way to the Network Adapter section and expand it by double-clicking on it.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-0.png 3. Figure out your wireless modem from the available list and right click on it to navigate to its Properties.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-2.png 4. This launches the Properties dialog box of your adapter. Hit on the Power Management tab. Clear off the option that saysAllow the computer to turn off this device to save power.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-5.png 5. To apply the changes, press Ok button. This will Fix Airplane mode not turning off issue in Windows 10 and resume its slider to be turned off.
Check the other solutions here Airplane mode not turning off in windows 10 Fixed
Aug 15, 2015 | Lenovo Computers & Internet
Engine sounds like an airplane taking off
Sounds like the engine cooling fan clutch is defective. If it remains locked up the noise does sound like an airplane.
Mar 18, 2015 | 2009 Chevrolet HHR
How do i take my phone off of airplane mode
That depends on the kind of phone. iPhone, you can swipe up from the home button and then tap the airplane icon.
On android, swipe down from the top, tap the little squares on the top right and then tap the airplane icon.
Dec 13, 2014 | Cell Phones
My chevey caviler makes a loud noise that sounds like a airplane
what kind of airplane..?no just kidding..maby see if you have a hole in exaust somewere.
Apr 08, 2014 | Chevrolet Cavalier Cars & Trucks
Maytag FAV6800 AWW transmission?
the noise is more than likely coming from the clutch as you correctly surmised that the transmission only functions the paddles. As far as the airplane sound during the spin cycle well that is a bearing issue also called the "spinner support". I would be very careful attempting to replace this part yourself as doing it wrong results in a very leaky washer. The clutch runs about $150 while the spinner support runs about $250 so even though the diagnosis of the tech was clearly wrong (transmissions are relatively cheap and are fairly easy to put into these machine) it still might not be worth the money. Maytag did extend warranties on clutches for very specific models but it only covered the part and not the labor so you may still wind up with an expensive bill. I hope this helped.
Nov 16, 2012 | Maytag Neptune FAV6800AW Top Load Washer
What are the main parts that keep the airplane in flight?
There are four main parts that keep the airplane running and functioning during flight. These parts are the wings, fuselage, cockpit, and the engine. For more detailed information on these four parts, check out this link: http://www.ehow.com/info_8113262_four-airplane-parts-keep-flight.html.
Aug 29, 2012 | Champion Sport & Outdoor - Others
Cant open phonebook,messages
To fix the problem and restore your connection (turn OFF airplane mode), click "Menu," then "Settings," then "Phone Settings," then "Airplane Mode," and then set the mode to "Off." Once you turn off the airplane mode, your Samsung phone will function as normal.
Oct 04, 2010 | Samsung Cell Phones
Loud airplane noise in GMC JIMMY
has the clutch fan been tested? was it a very hot day when this happened? if so the electric engaged engine clutch fan may have fully engaged, it will really roar when it does.
Oct 01, 2009 | 1997 GMC Jimmy
Loud noise from engine when in drive sounds like airplane
exhaust gaket leaking or a loose joint or both
Jul 23, 2009 | 2005 Scion xA
Kyocera Copystar CS-1620 Black and White Copier Logo
50 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
