My Jvc Slim TV shows stripes on the screen after changining burned capaciter due to over loded voltage
    President:
  • 1,961 Answers
Ok.lower down the screen adjustment of your plyback.there are two adjustment present on your plyback body.the upper adjustment is for the focus adjustment and the other one is for the screen adjustment.Turn it counter clockwise with the power of tv is on..
good luck hope i helped you..
please vote for my help..
Posted on Jun 03, 2010
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
The color on my Samsung Slim Fit TV suddenly blipped to pink and blue. When I turn it off and back on, it comes on with a green line across the middle of the screen. What's up?
This line shows that there is failure of vertical output stage,may be due to high supply from internal power supply of TV set,check the voltage of the vertical output stage,and after rectification of supply problem replace vertical output IC to get this problem solved.
Feb 08, 2011 | Samsung SlimFit TX-T2782 HDTV
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
How to trouble shoot problem with JVC Slim TV with blue color on lower leftcorner and green on the upper right color? Also, the display using VideoInputs are not correct horizontal.. the Screen is tilted....
http://www.go-gddq.com/upload/2009_03/09032313026620.pdf
www.scribd.com/doc/.../Sanyo-TV-LCD-Training-Manual
www.scribd.com/.../JVC-LCD-FLAT-Television-LT26WX84-Service-Manual
www.scribd.com/.../282-29-JVC-HD-ILA-Basic-Model-Training-2007
These service and training manuals above show you how to troubleshoot and isolate any problem, and what to do about it, please have a look and download and use all the information, in the manuals and you will soon isolate your issue.
May 19, 2010 | Televison & Video
Hi, I have a Vizio P42. Worked fine for 5 years. Today is has a vertical blue stripe 1.25" wide, 4" from left side of screen. Blue stripe remains even if all inpust cables are removed. Problem is...
it's burning out. that's a sign of tv failing. there is no repair for that if you used it for 5 years, i doubt you would have warranty for that by now, best option is to replace it.
Oct 17, 2009 | Televison & Video
AV-36980, c926 blown
Electrolytic "CAN" type caps fail for several reasons. 1. over voltage stress. 2. polarity reversal. 3. over current stress. These three things are caused by other components that have also failed or partially failed either before or after C926. Check the rectifier circuit and or the horizontal deflection circuit which gets it's filtered DC voltage from C926. louie12fix on fixya.
Sep 17, 2009 | JVC AV-36980 36" TV
Picture Tube alignment
the oscillation is not constant, there are two things to check in that tv. take your tv to a w/shop and let the following be checed
power output voltage if its constant from the power supply, changes.
secondly, check the variation of capacitance values on the power supply, and on the line transformer section.
dont gorget to test a line transistor also.
okay.
Apr 30, 2009 | JVC AV-36D303 36" TV
I have a JVC tv only 1 year old and the picture is getting dark.
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
BLACK ON SCREEN
High voltage problems..Anything from bad regulator capacitance, to defective flyback transformers....accordianman
Feb 27, 2008 | JVC AV-56P575 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
