Question about Garden
My poulan po475n21ra runs with a miss then goes to hi idle and shuts off
  • 391 Answers
The symptoms you describe sound like it's running short of fuel as though there is a pinhole in the fuel line leading to the carburetor. If you can see bubbles in the fuel line you have a small leak and that's all it takes to make that happen. Less likely but still potential reason is air leaking past the crankshaft seals leaning out the engine, if the engine has more than 25 hours on it the rings may be shot.
Posted on Jun 03, 2010
Rebuilt carb same problem engine runs at full throttle but when release throttle lever engine dies
Idle circuit is not working properly on the carb. If you have cleaned it as you say and are still having hassles you might just want to get a new one since working on those things can be a hit/miss situation and very frustrating.
Are you sure that you have the idle circuit jet adjusted properly? If adjusted too far in, engine will not get enough fuel and starve - shuts off.
Mar 04, 2016 | Poulan Garden
Bolens tractor motor k482 runs ok idle but bad when run fast, misses fire
Hi Sylvain:
Assuming the spark plug is good, I would pull the flywheel and look for a partially sheared key.
Mar 02, 2016 | Garden
Need to adjust hi lo idle settings but unsure how to start this process saw is poulan wild thing saw idles too fast and fast idle needs to come down
If idle speed is the only problem, there is a screw (not the two jet screws H and L) for this purpose. Turn the screw CCW until the chain stops turning, but the engine continues to run. Hope this helps!
May 17, 2010 | Poulan Garden
Poulan push mower question
Check the engine manufacturers web site. You will need your engine number. .....You will find an on line diagram and part numbers for your engine. Also, Most Mower Parts stores have the same thing !
Sep 06, 2009 | Poulan "Poulan" Push Mower
My Poulan runs for a few minutes then idles down shuts off. Get it running again does same thing
Check the governor spring to see if it is streched out or the bracket it attaches to is bent,this can cause the problem. Also the carb may need cleaned and rebuilt,if it contains a diaphram gasket it could be bad causing it to die.
Jul 01, 2009 | Poulan "Poulan" Push Mower
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
Dec 10, 2008 | Poulan Garden
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
