Question about Black & Decker Garden
Where can I buy a batterypack for the GS 720 Type 1
Mfg. year of Savage 720 serial no. 66499
we do not do guns here . try a gun store
Jan 11, 2016 | Motorcycles
How to replace batteries in batterypack of travelmate 270?
http://www.battdepot.com/us/model/Acer/TravelMate+270.aspx?gclid=CJD2oLTw_L8CFQmoaQodn2EAQw
Aug 05, 2014 | Acer TravelMate 270 Laptop Charger...
What does fsh, gfs mean
It may mean you need to buy a vowel? Sorry, I know that's not helpful. These are codes for HD recording modes.
" HD Movie Recording 1920 x 1080 pixels, 50i (Sensor output is 25p) (FSH: 17Mbps, GFS: 17Mbps / AVCHD) 1280 x 720 pixels, 50p (Sensor output is 25p) (GS: 17Mbps, SH: 17Mbps / AVCHD) 1280 x 720 pixels, 30 fps (QuickTime Motion JPEG)"
Jul 28, 2012 | Panasonic Lumix Dmc-ft3 Waterproof Digital...
How to repair batterypack pa3191u-5brs toshiba
Go to www.ebay.com type make and model of laptop, refine search to battery, there are aftermarket and genuine batteries to choose from.
May 31, 2012 | Toshiba Computers & Internet
I need reset switch i started unit under load blew breakers
We really need a complete model number to get to an IPL that has your parts. This generator has 4 variations Type 0, 1, 2, & 3.
(Type 1 link below)
http://www.ereplacementparts.com/porter-cable-bsv750w-type-gas-powered-generator-parts-c-129_1825_2153.html
Parts manual pdf: (Detail A)
http://www.ereplacementparts.com/images/Porter_Cable/BSV750-W_TYPE_1.pdf
Breakers are item 206:
206 Z-GS-0026 BREAKER CIRCUIT 125/ 1
206 Z-GS-0681 BREAKER CIRCUIT 125/ 1
206 Z-D21508 BREAKER CIRCUIT125/2 1
Thanks for choosing FixYa,
Kelly
Sep 12, 2011 | Porter Cable Portable Generator BSV750
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
I'm looking for a backup battery for loox 720. I will visit Munich next week, is there a place to buy such a battery? Thanks for your help.
why dont U get access to 1 Esource ,i bought a backupbattery for my ipad from a retailer in the market,but on the case shows 1 Esource Technology,so i do think this backup battery made by them,and it is very good,
Jan 06, 2011 | Fujitsu Siemens Pocket Loox 720 Pocket PC
My LCD touchscreen on my DCR-SR45 fades to white
To resolve the issue,
Please open the LCD screen to locate the RESET button.
To reset the Camcorder, just press the RESET button using a sharp-pointed object.
Please make sure that the Camcorder is turned on while pressing the RESET button.
If the issue still persists, Power Reset the camcorder.
To reset the Camcorder, please remove the batterypack from the Camcorder and then set the Power Switch to ON for 15 seconds.
Then, reinsert the batterypack after 1 minute and check if that helps.
Mar 20, 2010 | Video Cameras
Jvc model gs 720 radio not working after battery replaced
Check the fuses at the back of the unit and in the fuse box.
Jan 05, 2010 | Car Audio & Video
Search inside toshiba tecra m4 s435 tablet pc cmos battery
the cmos battery is nearby with the batterypack..it is connected into mainboard by using 2 wire...and it sticked into the batterypack plastic
Nov 14, 2008 | Toshiba Tecra M4-S435 Tablet PC
Garden Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
