Question about Microsoft Xbox 360 Controller
My controller just shows all four lights flashing and when i try to sync it, the lights just keep spinning round and does'nt connect
    New Friend:
  • 13 Answers
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Posted on Jun 17, 2010
SOURCE:
How I fix the xbox 360 controller blinking and sync light problem,when the sync button doesnt work?
My only guess would be that you disconnected the cable to the sensor while cleaning your Xbox. Have you checked all the connections before reassembling it? Check out the video I linked, maybe it'll help you!
Dec 16, 2014 | Microsoft Xbox 360 White Console
Tip
How to sync your Xbox 360 wireless controller
I have come across a few questions asking why a wireless controller is on but not connected, or why it is on and no corresponding green lights were on, etc.. So here it is: DRAGONF1R3 REPAIRS' GUIDE TO SYNC YOUR XBOX 360 CONTROLLER TO IT'S CONSOLE
Quite a title I know, but the actual guide is very simple.
Step 1: Power on your Xbox 360 console. In this guide I'm assuming everyone already has their console hooked up, if not, contact me.
Step 2: Power on Xbox 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Step 3: Locate the small circular sync button on your controller. It is near where your controller can be plugged in (between the LB and RB).
Step 4: Locate the small circular sync button on your Xbox 360 console. It is next to Memory Unit slot 2.
Step 5: Press and hold the controller sync button until the green power lights start spinning.
Step 6: While your controller lights are still spinning press and hold the console sync button. The console's lights should spin also, then flash, and finally show the player slot light on both the console and the controller.
Viola! You've synced your wireless controller! You can sync up to four controllers.
Also, you can use this guide to sync to different Xbox 360 consoles. So you can bring only your controller to your friend's house.
Note: If you sync your controller to another console, you will have to re-sync it to your own afterwords.
on Jan 18, 2010 | Video Game Consoles & Games
Yes, this can be tricky sometimes.
Be close to your console when synching your controllers. As always make sure the controller is on.
You will need to press both the synch button on the console and on the controller approximately the same time. If you have done this correctly. The controllers should have synched to the console in a few seconds.
Here is a link to show you how to do it for the Xbox 360.
Connect controller to your Xbox 360
To synch a Xbox One Controller go to link below here.
Connect wireless Xbox One controller to your console
Also just in case the light is flashing the and the controller is already synched, that means the battery is low and you need to change it out for new batteries.
Hope this has helped and good luck.
I cant figure out how to sync my guitar to play guitar hero
First of all make sure your guitar hero controller turns on and flash's. Next, you will see at the bottom of the guitar hero controller there is a little button. On your Xbox 360 there should also be a syncbutton which you use to sync controllers. Hold the sync button down on your Xbox and at the same time on your guitar hero controller as well. You should see that the lights on your xbox and controller spin round and then flash a few time in till displaying one light next to the appropriate number. Please note that you cannot use a Rock band controller on Guitar hero. If You controller still does not connect then try changing the batteries in case they are low, but if the problem continues to persist then you shall have to call Xbox customer support by going to www.Xbox.co.uk .
Sep 14, 2010 | Activision Guitar Hero III: Legends of...
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
My controller will not link with my xbox. it just flashes 4 green lights around the circle. what can i do?
Did you sync it? here's how to sync it:
Step 1: Power on your Xbox 360 console2_bing.gif. In this guide I'm assuming everyone already has their console2_bing.gif hooked up, if not, contact me.
Step 2: Power on Xbox2_bing.gif 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Jan 23, 2010 | Microsoft Xbox 360 Controller
No light on console, lights blinking on controller - won't stop
try this not sure
Turn your xbox 360 on. Hold the sync button on the xbox 360 until the spinning wheels go away. Unplug your power. Unplug hard drive for 1 minute. Put hard drive in, then power, and it should work.
Oct 06, 2009 | Microsoft Xbox 360 Console
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Wireless Les Paul guitar light keeps flashing after I sync to 360
I had the excact same problem with a Microsoft wireless controller. It just showed it synced fine and the controller dropper off the rig right after, keeping blinking idly as always when unconnected.
Solution: When you power the console on with the X button on the controller, try pressing the connect button on the controller then, apparently the console looks for controllers when it's just opening the user interface. Had to try it twice but it synced fine just as I was giving up hope, and has been working ever since!
May 29, 2009 | Video Game Consoles & Games
Wireless controls wont synch to sytem i changed batteriespressed both little buttons but controller just keeps on blinking
First I'd test the batteries in another device to make sure they actually are full. Rechargeable batteries are great in the long run and also generate less waste.
I had the same problem with a Microsoft wireless controller. It just showed it synced fine (the four leds blinked in order 1234 and then all flashed like it's connected) and the controller dropper off the rig immediately after that, keeping blinking idly as always when unconnected.
Solution: When you power the console on with the X button on the controller, try pressing the connect button on the controller then, apparently the console looks for controllers when it's just opening the user interface and it somehow synch better at that moment. Had to try it twice but it synced fine just as I was giving up hope, and has been working ever since!
Hope I could help!
Dec 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
1,444 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
