Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
How does the control panel work? low numbers warm etc?? I inherited my partners mothers fridge freezer, unfortunatly it didn't include the instrution book,I have had it running on number 2 but it seems to freeze things too much
  • 402 Answers
Typically the larger the number the colder the setting. Is there an arrow on the knob that points to the left or right that says "warmer" or "colder" I also question your comment "freeze too much" because this is a freezer only, it will not keep things "cool" if you turn it up enough. If you mean there is frost on everything that is humidity and not the freezers fault.
Posted on Jun 03, 2010
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
My Daewoo Fridge/Freezer is not freezing. The fan is still working and the compressor still seems to be working, or at least it is hot at the back. It is about ten years old but it is a solid machine and...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 17, 2011 | Freezers
Old Kenmore frostless upright freezer 19.6 cu ft. Model 38202. It is running but not freezing. Is it worth a service call?
NOTE: This
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 31, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
I don't have the model number. Fridge/freezer five years old with an electronic control panel on the freezer door. Freezer temp not showing, nor can it be adjusted. Freezer temp lowering, but appears to be...
Well, its good that it is still cooling, however since you cannot adjust the temps, you do still have a problem, and one that may include the unit fails to cool properly.
Oct 04, 2010 | Whirlpool Freezers
Fridge freezer freezer ok fridge warm willnot chill
dear sir/madam
i think there can be possible low gas problem it,s naturally if in your freezer there is low gas then it,s coil get warm. it,s coz of low gas so please contact to your service technician for find out leakage and brazing it and then refill the gas. i hope after that your freezer will work well.
hope answer the question
thank you
please vote!
Aug 30, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Frigidaire side by side works fine for a couple of days then it starts to get warm, milk gets warm n ice starts melting. i unplug for a day n i when i plug it back in tll work for a couple of days...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 25, 2009 | Freezers
Freezers Logo
269 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
