Question about Lexmark C530dn Laser Printer
When pages print out they have black and syan colour down the edges
  • 241 Answers
You may have a build up of toner on your drum unit or fuser. I recommend a cleaning to resolve your print issue.
Posted on Jun 04, 2010
New ink colour printer not printing black. Prints all other colours but not black when print tested
Hi there!
If the test page from pc or the machine test page doesnt show black, what you can do is to clean the printhead. To do that press the Ink Management button on the control panel and select cleaning press ok then press the up or down arrow key to select Black press ok and press Black Start. After the cleaning process print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times.
Hope this helps Please rate if it worked Thanks!
Mar 30, 2011 | Brother DCP-585cw All-in-One Wireless...
Printer is printing yellow instead of red and colour is fade
The magenta has run out (red).
Replace the HP 22 tri-color cartridge.
It probably has yellow and cyan (blue) left in it, and the black is most likely working as well, but if any of the 3 colors in the tricolor cartridge run out, the whole cartridge must be replaced.
For instance, if I printed my vacation photos and there was a lot of water and blue sky in all of them, the cyan might run out long before the cartridge life expectancy.
Also, don't forget that cartridges are rated in pages printed at 5% coverage.
Since a photo is about 25% of a full page, a photo printed at full bleed (edge to edge) will only yield 32 4 X 6 inch photos from a cartridge rated at 160 pages (5X expected coverage = 1/5 the prints)
Mar 27, 2011 | HP DeskJet F380 All-In-One Printer
How many pages print out black and color?
Black prints - 200 pages
Colour prints - 360 pages
Black Print speed : 28 pages per minute
Colour Print Speed : 22 Pages per minute
Jan 25, 2011 | HP OfficeJet J4580 All-In-One Laser...
When printing the sheet of paper has 3 dots on the
Yes this could be the drum.
You could remove the drum and carefully look for the pattern of dots etc that you are getting on the page but on the drum surface.
I would suggest replacing the drum 1st and retrying.
If the black lines are just down one edge then the fuser could be to blame for the black marks but without being able to see the page i cant tell. The drum is certainly my 1st suspect and is easy for you to try.
If you are in Berkshire try www.repairmyprinter.co.uk for additional help
Aug 24, 2009 | HP LaserJet 2840 All-In-One Printer
My pages are printing correctly on the edges but light in the middle on my clx 3160fn. it has a new black ink cartridge
Is it only with one colour ? I had the same problem (only with black) and before buying another unit dismantled the imaging unit to find a build up of toner on the metering plate edge, I cleaned it and now it's fine.
It takes a bit to get to... 3 fixing screws each side plus one for the belt shute and one at the top. Remove the side plates, followed by the image drum (with great care) then each colour toner roller unit (they just slide forward) until the black unit is exposed. Remove the 5 cover fixings and then you can clean the plate edge. kh
Jul 11, 2009 | Samsung CLX 3160fn All-In-One Printer
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printing faint
hi
I believe this is a timing problem, you have done alot yet the same problem recurs . Compare the toner drum assembly holder positioning with another similar printer to justify its timing. Remove this holder drum and inspect the metallic contact tracks behind it.
keep me posted on this
labatt
Jan 29, 2008 | Epson AcuLaser C900 Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
Lexmark C530dn Laser Printer Logo
168 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
