Question about Tecnik TKL9290 Front Load Washer / Dryer
Not turning on when switched on, electrics to socket ok and fuse ok
  • Tecnik Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
jfk
Posted on Sep 29, 2010
2001 Mercedes c240, both electric seats stopped working. Fuses under the drivers side dash all look ok.
Please look under the seats for a disconnected wire socket
Hope this . helps Mike
Apr 30, 2017 | Cars & Trucks
My Chrysler 300 won't start. Problem is not battery or fuses. Not getting 12 volts to 5 amp fuse (fuse is good) for control voltage to starter relay. Applied 12 volts to fuse socket with ignition s
PLease, check if the check engine light lit up when you turn the switch, if it doesn't lit up, your EMC (computer) is not getting any electricity. And that could be the reason that you the fuses are OK but it won't start.
Jan 19, 2015 | 2007 Chrysler 300
03 chevy venture rt.front parking light&turn light don't work replace bulb&socket
The rapid flashing occurs because of the light problem. If the 20A PARK LP fuse in the underhood fuse block is OK, the front marker lamps and the park lights should turn on when you set the headlamp switch to PARK. If the 10A T/SIG fuse in the instrument panel fuse block is OK, and the ignition switch is on, moving the turn signal multi-function switch to signal a right or left turn should cause the turn signals to flash. If this doesn't happen, check for a missing ground connection to the socket you replaced and check to be sure the replacement lamp was not forced into the socket backwards (it happens).
Sep 17, 2012 | 2003 Chevrolet Venture Passanger
Hp t450 desktop won't turn on
is there a reset button anywhere on it
Dec 05, 2011 | HP Computers & Internet
2002 honda accord v6 front left power window does not open,20A fuse is OK what would be next step to check Thanks Ivo
Next step would be to check the power switch on the door. There is one screw hidden with a plastic cover at the bottom of the pull in (bay?) handle (NO NEED TO TOUCH THE OPENING HANDLE). Dismount the window switches subpanel, and check that the socket is properly attached, and with clean contacts.
This is also a good time to check if the switch is receiving electrical power ( with the ignition turned on)
If there is electricity at this point, then the switch is burned, or the window electric motor gave up the ghost.
Jan 23, 2011 | 2002 Honda Accord
2004 Grand Prix GTP. My headlights won't turn on. We replaced the relay and checked all the fuses (good) and still nothing.
check headlight bulb first/ then the socket if ok check switch then the electrical wiring connections it must be one of those...
Apr 09, 2010 | 2004 Pontiac Grand Prix
Reverse light fuse blows when put into reverse
Unfortunately, many possibilities. If you have time, start by removing both reverse lamp sockets from light assembly(and keep from touching any metal), remove bulbs from sockets, CAREFULLY INSPECT sockets and wires. New fuse of correct rating. Turn key on and try again in reverse.
Fuse still blows: Next place to look is transmission reverse electrical switch and wiring as far as you can trace looking for burned/stripped wires near transmission and wires by sockets
Fuse doesn't blow: Turn key off and install one lamp in socket at a time. DO NOT install sockets into fixture at this time. Test. Remove first lamp to check second. If still O.K., each socket back into fixture(one at a time same as before)and test. Most common problems: Sockets contaminated, wires shorting at sockets, bulbs installed incorrectly shorting to ground.
Sep 25, 2009 | 1996 Ford Explorer
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Plug sockets only failing
The age of the electric wiring could be an issue. I suspect a bad or loose connection at the recepticals. If appliance plug- in results in a loose connection,( IE: Plug falls out ). Replace the duplex recepticals as needed. Also check wiring connections to be sure they are tight.
Nov 26, 2008 | Kitchen Appliances - Others
Washing Machines Logo
63 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
