Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Ink replacement issue!!
Hello. I own a brand new Epson Stylus Sx110, my black ink run out so I went to the store and replaced my black ink with the corresponding black ink ( its epson). It STILL says that the ink is not recognized and I should replace it. What the hell?
  • 600 Answers
Have you bought genuine ink??? well if your answer is both yes or no, you can always opt to have it replaced from where you bought it, but please try to buy genuine inks, so as you will have no problems regarding ink cartridges.
Posted on Jun 03, 2010
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Repalced the ink in my epson sx110 and it stills says no ink
Try to remove and reinsert the cartridge. If that doesn't work, I would just replace the printer.
Apr 30, 2012 | Epson Office Equipment & Supplies
I have an epson stylus NX100 and i just put brand new black ink in it recently i printed two pages max i went back to use it and it says that my black ink has expanded and i have to buy a new one? what...
***hi there,ill be willing to help you on that. ****
try to reseat the cartridges first to charge it again, reseat means Remove and reInstall the Cartridges. after doing that and still the same issue, and you have an extra set, try to load another brand new ink,just to isolate if it is the ink thats causing the problem, if the same issue persist, its not the ink that you bought, its the printer already, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
If the ink light is flashing, a cartridge is low on ink; replacement is recommended.
2. Open the scanner and prop it up with its support
3. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended.
4. Press the nx100_tx100_ug.1.93.8.jpg Stop button again. If another cartridge is low or expended, it moves to the nx100_tx100_ug.1.93.9.jpg position. Press the nx100_tx100_ug.1.93.10.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7Remove the cartridge from the package
8. Remove the yellow tape from the bottom of the cartridge.
9. reInsert the new cartridge into the holder and push it down until it clicks into place. 10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner.. 11. Press the nx100_tx100_ug.1.93.18.jpg Stop button to begin charging the ink. This takes about 1 1/2 minutes. When the nx100_tx100_ug.1.93.19.jpg On light stops flashing and remains on, ink charging is finished. Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
Jan 21, 2010 | Epson Stylus NX100 InkJet Printer
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Epson stylus PHOTO R350 Repeatedly indicates 'out of ink' for all colours despite replacement and nil or minimin subsequent use----am extremely frustrated by this, am consideriing buying new...
Out of ink for all colours? If you don't use CISS, are the replacement ink tank new? Chip in ink tank stored ink level counter. If it reach zero, chip can't use. Check chip contact at ink tank, and chip connector at head carriage. Don't be frustated, man. I have thousands experiences like that. Two unsolved, that board is burning. If, chip conector is clean, use chip that no reach zero level. Good luck.
Jun 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Feb 11, 2009 | Epson Stylus 830U InkJet Photo Printer
Epson Stylus C86 Printer Ink Refill
The chip that is located on the cartridge has to be reset also. You can take it to a ink cartridge replacement store. They will reset the chip when they refill the ink, however, Epson doesn't recommend this of course. It is cheaper this way.
Aug 15, 2008 | Epson Stylus C86 InkJet Printer
Printer will not print black, but will not let me replace black cartridge
The Epson FAQ lists several techniques for resolving this problem. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14374&infoType=Overview There is also an animation on how to replace the ink cartridges. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=HowTo&oid=14374&prodoid=11473
Oct 14, 2006 | Epson Stylus 880 InkJet Color Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
501 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
