Question about Stinger Adjustable Line Output Convertor 55 Watts
How to wire to factory 1999 jeep grand cheerokee
  • 12,061 Answers
Locate the wires running from the head-unit or factory amplifier to the speakers. In some cases you will find these wires behind the head unit, but it may be easier to go directly to the speakers.
Once the speaker wires are found, use the wire strippers to remove 1 inch of insulation from each one. Attach the left channel of the L.O.C. to the left speaker, and the right channel to the right speaker.
Solder the L.O.C. wires to the speaker wires and seal the connection with heat shrink or electrical tape. Secure the L.O.C. to the vehicle. Plug in some RCA cables to the L.O.C. and run them to the amplifier.
Adjust the amplifiers' gain levels to a medium setting. Turn on the stereo and adjust the volume to a comfortable listening level. Use a small screwdriver to adjust the gains on the L.O.C. up until distortion is heard, then turn the gain down until it goes away.
Turn the volume up on the head unit and make sure that there is no distortion present in the amplifier. If distortion is heard, adjust the gain on the amplifier and L.O.C. accordingly.
Posted on Jun 03, 2010
How do i bypass a security code on a 1993 jeep grand cheerokee?
Use your key to lock and unlock the rear hatch lock. That should temporarily shut down the factory security.
Dec 29, 2010 | 1993 Jeep Grand Cherokee
Where is the blower motor for the air conditioner on a 1999 jeep cheerokee located
should be located under the dash by passengers feet, you'll have to take a plastic cover off to locate it
Sep 19, 2010 | 1999 Jeep Grand Cherokee
Looking for detail on replacing vent doors on 2001 grand cheerokee like chiltans picture
See the write-up at www.wjjeeps.com for this problem. Also consider the solution at www.jgcparts.com ( this solution is quick and easy but ties the driver's and passengers temp control together.)
Feb 04, 2010 | 1999 Jeep Grand Cherokee
Wiring diagram for a 1993 Jeep Grand Cheerokee
In here you can find information and the repair Manual for 93ZJ-Secc-8W-Wiring-Diagrams
I really hope helped with this, remember rated this help. Good luck.
Nov 24, 2009 | 1993 Jeep Grand Cherokee
1994 Jeep Cheerokee Laredo: The remote keyless
If it is a factory alarm you can't unhook it. Replace the switch attached to the lock cylinder inside the door. In the meantime, the switch on the passenger door may still be good. Cycle the key in the passenger door to see if it turns off the alarm.
Oct 16, 2009 | 1994 Jeep Grand Cherokee
Grand cheerokee with no heat.
this is a blower motor resister it is a cirurite board thay is attched to a wire that plugs in to the blower motor
if this helps you please take a moment and rate my responce
Dec 11, 2008 | 1999 Jeep Grand Cherokee
1999 Jeep Grand Cherokee Problem
Idle prolem could be a dirty throttle body or sticky air idle control motor.
If the Jeep is a 6 cly. the adjustment for the belt is the power steering pump.
If the Jeep is an 8 cyl. the tensioner is on the pass. side of car.
Oct 17, 2008 | 1999 Jeep Grand Cherokee
Stinger Adjustable Line Output Convertor 55 Watts Logo
57 people viewed this question
Top Stinger Car Audio & Video Experts
xxxxxx xxx
Are you a Stinger Car Audio and Video Expert? Answer questions, earn points and help others
