Question about Metrologic Instruments MS5145 Handheld
I need to obtain the windows 7 Driver for a MS5145 FS USB scanner
Can anyone help please
Regards
Keith
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
Sep 04, 2011 | Fujitsu fi-5120C
I need to download a Mustek SE A3 USB 600 PRO Driver for Windows 7 for the device which got lost.
Hi anderoland
There is no support at Mustek's for Windows 7 . You can't use your device under this OS .
best regards ,
fanaudi .
Sep 02, 2011 | Mustek A3 USB Flatbed Scanner
My mac is not recognizing barcode reader honeywell MS5145
The scanner may need drivers, check for the brand name and go to their website to find the required drivers (if any.) If you already have drivers installed, try other USB ports.
May 04, 2011 | Honeywell MS5145 Eclipse with Codegate...
What kind of cables do I need? my friend says that they are doggles - or something like that
RS232 Barcode Scanner Cable
Handheld scanner cable
Connector: DB9, DB15, RJ45
Cable: PU, PVC, 26AWG, 28AWG...
Application: Computer POS system, Scanner 0R Metrologic Honeywell barcode scanner MS9540 MS5145 USB Cable ???4 Similar from this Supplier Straight USB Cable with chip for Honeywell Metrologic MS5145, MS9540, MS9590, ETC....
May 04, 2011 | Computers & Internet
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
Looking for the Vupoint Filmscanner driver. Thanks for helping..
Hi Thierryghi,
thanks for explaining in detail.
Please download the driver for your device from the below link.
ftp://vps:vps@66.185.19.4/Drivers/FS-C1-VP.zip
But I am not sure whether it will be compatible from Windows 7.
Try installing the driver. If not installing on win 7, then right click on the setup.exe and select properties. There select compatibility to windows xp as something similar like below.
After installing the driver, you need to install software so that you can use that software to scan.
Please download the software from the below location and insatll this as well after installing the driver.
ftp://vps:vps@66.185.19.4/software/PhotoImpression_6.1.8.130(new).zip
After installing this s/w you will be getting some shortcut in desktop using which you can scan your film.
I hope this will be useful to you.
Thanks
Mar 10, 2010 | Office Equipment & Supplies
Metrologic Instruments MS5145 Handheld Logo
268 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
William Robinson
William Robinson
Sandeep Kumar
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
