Question about Candy AQUA1000T Front Load
Candy aqua 10t user settings
What do the numbers on dial mean i assume other dial is wash temperature
  • Candy Master
  • 12,061 Answers
Http://service.candy-domestic.co.uk/manuals/pdfs/AQUA%201000T.pdf
I have found you a user manual, to download and read, this should help you resolve your issue.
Posted on Jun 03, 2010
Hi ;vejust bought a candy fridge freezer model n0 turned dial to super lights were on constant but now the orange light is flashing what does this mean also some of my meat isnt freezing
What's the model number of your fridge and what type of meats are you putting in and how much at once and what's the temperature of the meat +-, I'll explain everything and give you the best solution.
Regards
Jun 07, 2016 | Candy Refrigerators
My upright Candy fridge freezer is 14 years old. The fridge is 5 the freezer is -27.9 how can i adjust it?
turn the dial to a lower number . wait a couple hours and check temps if not low enough set even lower number on dial till it gets where you want it .
May 12, 2015 | Candy Refrigerators
I have a Candy GOF 662 and the dial seems to be out by two Programs
There is a plastic lug broken off inside the dial. If you pull the front bit off you will see that the front is held in place by it. You probably need a new dial, but, in the meantime, mark the front bit with a permanent marker with numbers corresponding to each function you need. It may not be the same number of clicks, but it will be the same distance around the dial.
Apr 26, 2014 | Candy Washing Machines
What temperature shoud it be on please - it has from 1 to 3
I would suggest setting it on 2. But to eliminate guessing, the dial should be set so the temperature in the freezer compartment is 0 degrees F (-18 C). The best way to ***** this is to put a thermometer in the freezer and adjust the dial until the temperature is steady at 0.
Charlie
Mar 16, 2011 | Candy 2.5 cu. ft. / 71 liter Upright...
Candy aqua washing machine has power but wont do anything
Try plugging or unplugging the Washing Machine
I hope this works
THANKS
Dec 09, 2010 | Candy AQUA1000T Front Load
Manual need for a candy aqua washing machin
phone candy 08705 400 600 you will need your model number .
Feb 12, 2010 | Washing Machines
Defy Fridge temperature dial is confusing - which way is colder?
0 = off, 1 = cool, 2 = cooler, ..... 7 = coldest.  0 - 7 Nothing to do with the degree the fridge is set to.
Jan 07, 2009 | Refrigerators
Candy Aqua 1000
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Oct 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy AQUA1000T Front Load Logo
334 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
