Question about Whirlpool Duet GHW9150P Front Load Washer
Ignis Oven functions
I am renting a flat and there are no instructions for the oven, the function symbols are a square with a light at the top, a square w 2 lines and a square with a line at the bottom. To cook I have tried using the one with the botton line (and of course selecting a temperature) but it seems to take a really long time to cook something and food does not brown, if I put on the symbol with 2 lines it looks like the grill is coming on because the element lights up (the fan is going aswell) Is this right?
Julia Fowler
  • 19 Answers
Definately the control with 2 lines where the fan kicks in. The grill and oven elements will come on. The fan will disperse the heat from the grill element evenly and more quickly inside the oven. You will need to reduce cooking temperatures by about ten percent though,or youll burn your dinner. Also keep food down ,not too close to grill element at top of oven, middle is fine. Hope this helps. Regards..
Posted on Jun 02, 2008
How to fix creda cooker all of the hobs when put on are unable to control heat
[PDF]Product Directory Summer 2013 - Creda Heating
www.credaheating.co.uk/assets/kb/brochure/.../Creda_Nobo_Brochure.p...
Creda Heating range, installation and operating instructions, brochure ... installations. We are able to offer an expert application design service for all our.
The Different Functions And Uses Of The Oven - Creda ...
www.manualslib.com > ... > Instructions for installation and use manual
Creda J052E Instructions For Installation And Use Manual: The Different Functions And Uses Of The Oven ... For all other types of. cooking, never ... cooking functions are set up by operating the two knobs: ... The oven light turns on and the top and bottomheating ... permit reaching the maximum (250°C) temperature inside.
[PDF]Instructions for Installation and Use - you
Jan 24, 2016 | Creda Kitchen Ranges
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Sep 09, 2014 | Kenmore Kitchen Ranges
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
Mar 21, 2013 | Neff B1641 Single circotherm super...
We just moved into new flat with a whirlpool oven Model No: 6AKP524/1X. There's no manual. What are the 4 buttons on top/front for.
Unfortunately we are unable to offer assistance to those residing outside of the United States. Please visit http://www.whirlpool.com.au for assistance in your region.
Jun 09, 2017 | Whirlpool Ovens
Oven doesn't heat up and no light symbol shows up on the indicator panel.
it sounds like you tod stat has gone if you turn the oven off from the mains pull the oven right out and take the lid off you will see a little black stat with two wires join then up together do not let them tuch any thing then turn the oven back on if it all works afther you put the time in you will need a new one of them ok hope i have helped you
Nov 03, 2012 | Bosch Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Oven failer
You have reset the timer from the auto function, to the manual function.
You should see a hand symbol showing for manual operation.
It is a question of pressing the buttons in the correct sequence., or if it is a anologue timer, turning the knob until you see the hand symbol showing.
Hope this helps.
Dec 24, 2009 | Zanussi ZBF360X Electric Single Oven
Zannusi built in oven
Solid line at top indicates the grill. Two indicate the oven.
Sep 21, 2017 | Zanussi ZHQ575 Electric Double Oven
Whirlpool Duet GHW9150P Front Load Washer Logo
2,027 people viewed this question
Dan Webster
Dan Webster
Sal De
