Question about Honda Landa PG 3500 PSI Pressure Washer
13hp honda motor what is the right psi for it
13hp honda motor what is the right psi for it thanks
    Scholar:
  • 45 Answers
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Posted on Feb 14, 2011
I have the John Deer 3800 psi from lowes. The machine is in great running order it just seems to be losing psi as I use it. Also checking the oil in the Honda 13hp motor and in the pump. Do you take the...
Thread the dip stip back in to get a true reading of the oil level. Either oil filler may be used to top off the crank case. There is only one crank case - the oil on one side is the same oil seen in the other filler.
Apr 12, 2011 | Briggs & Stratton Garden
Run fuel line from truck tank to 13hp honda engine
This will work if the 13hp engine has its own fuel pump to draw fuel from the tank. Sounds like a good idea, use as mush steel line as possible to prevent line damage and associated leaks.
Apr 17, 2010 | Air Tools & Compressors
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
Pump burned up?
The unit does not have auto shut off? Anyhow try to take out the oil and flush it by running good oil in and let it out again…then put oil and first see if you can turn it manually few turns and see if you hear any sound…then try to start it and see…let me know
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | Honda Pressure Washer PSI 3000
Honda 13hp pressure washer cant get gas to my carburator
Hi there
If you have a Honda engine there's a fuel screen filter under the tank .
To get to it you have to remove the tank and turn the tank over so you can acess the filter. There's only 3 bolts holding the tank .
Check also the shut off gas valve by the choke .
Hope this help
Aug 29, 2009 | Karcher 2500 PSI Pressure Washer
What is the gap setting for a 13hp honda motor
20 Thousands will work. If it does not, the you have other issues.
Apr 18, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
Honda Landa PG  3500 PSI Pressure Washer Logo
225 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
