Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My washing machine has stopped working altogether on the spin cycle. It started with a crunching noise ( maybe cavitation in the pump) but still pumped water out and the noise disappeared at high speed. Now it's not working at all on the spin cyle.
  • Hotpoint Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineMy washing machine has stopped working altogether - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
During the spin cycle the washer makes a loud noise and now it wont spin or drain water
If the 'loud noise' water sloshing you should first check that the pump filter isn't blocked. This sometimes stops the pump altogether. Coins, etc..If the noise is metallic it could mean bearings...Check the pump via the small door at floor level...Mind the water inside the machine. You may be able to drain first with a small hose which is inside the pump access door.....Nomess
Apr 15, 2010 | LG WM2496H Front Load
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
Dec 29, 2009 | GE Profile WPRE6100G Top Load Washer
My washing machine won't turn or spin.
ok on the bottom there is a donut looking connector with holes and it needs replaced unless its belt drivin
Aug 14, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirring noise in spin cycle, 7 year old machine
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Oct 19, 2007 | Maytag Performa PAV2200
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
136 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
