I have a viewsonic VE510Eb touch screen..the problem is when you turn it on there is a display but only a secong the display gone but power led is green or on
  • 4,737 Answers
Boot from the Safe Mode and change the display resolution... if you have problem doing this, please let me know.. Good luck. Thanks for using FixYa.
Posted on Jun 03, 2010
TD2340 touch only works occasionally
If it has been working okay till now I would cleand up my hard disk after having unstalled the driver, do a disk cleanup and a defrag. MAYBE A RECOVERY TO A TIME IT WAS WOEKING.
aLSO TRY UNINSTALLING DIVER FROM WINDOWS, CHECK WHETHER IT IS IN STALLED IN PROGRAM MANAGER; IF IT IS REMOVE M THEN RESTART AND REINSTALL
Jun 06, 2015 | ViewSonic TD2340 23" LED LCD Touchscreen...
Why does my touch screen not work on my viewsonic viewpad 10pro?
at this point, i would recommend to try to perform factory reset to see if only software problem, not HW. You should be able to reset the device by locating little reset hole and pressing it down for 10s, using so sharp object.
May 31, 2014 | VIEWSONIC DISPLAYS Viewsonic Viewpad 10pro...
My viewsonic N3751w 37 in, tv will not power on
Is the status LED light on at all, if so what color is showing? if the LED doesn't even't light up, then the power supply is gone. Also, have you try using another power cable?
Dec 03, 2013 | ViewSonic N3751W 37 in. LCD Television
Viewsonic VA703 B, the problem is that I was normally using my computer, suddenly the screen got a "fuzzy" display for a second and inmediately turned off. I proceeded to get it on again, but the power led...
angepor, Might need to visit YOUTUBE for video clips on how to refurbish the power supply / inverter board inside the 703b! Look for electrolytic filter capacitors with swollen tops on them. All should be flat!! Also note the name beand printed on the side of the capacitors and let me know with a reply to this response.
12fixlouie
Sep 21, 2010 | ViewSonic VA703B LCD Monitor
Display on and off
that problem is very common on a viewsonic tv.you need to open the back cover of your tv by removing the four screw.you can immediately see the power supply of your tv after the cover is remove..It is a small pc board where the ac power cord is connected..First using a multitester measure the output voltage of the power supply.the output must be 5v for cpu,12v for sound and 24v for the inverter board.this inverter board is the one responsible for illuminating the screen of your tv...if the output are complete,,replace the converter board..if one voltage output of the power supply is missing replace the power supply board...g
good luck!hope i help you...
please vote for my help tnx..
Jun 03, 2010 | ViewSonic VE510b Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
Vx900 no video display or on screen display. When powered up video signal displays for less than 1 second and then is gone. Power LED is stays solid green on, have tried other monitors and video signal is...
This monitor has a back-light problem and it could be a faulty inverter board or a faulty CCFL lamp.
For service parts and DIY info, check out LCD Parts, please click on this link to their WEB site :-
www.lcdparts.net
Feb 17, 2010 | ViewSonic Computers & Internet
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Computers & Internet Logo
David Payne
David Payne
