Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Not displaying power is on but not displaying anything screen is black
    President:
  • 1,961 Answers
Let us be sure first if the power of your tv is on.
1.do you hear a sound coming from your tv?
2.is the remote sensor of your tv is responding once you press a button?
if the answer is yes then your tv is on!
to fix the problem, open the back cover of your tv.once it is open plug it to your wall outlet and power on.be carefull not to touch the live components of your tv..there is a small pcboard that is plug in to the end of the picture tube it is called the crt board or the cathode ray tube/tv color amplifier.At this board you can see the crt socket that connects the picture tube and the CRT board
the crt socket has labels on pins they are KR,KB,KR,and H1,H2.
Posted on Jun 03, 2010
  • Danilo Baraquiel
    Danilo Baraquiel Jun 03, 2010
    continuation of my answer, the H1 and 2 are the heater.The heater is the one responsible for lighting the screen...using your multitester,measure the h1and h2 pins.set your tester to ac range there must be an ac voltage signal of 3vac-8vac.If there is no voltage present,trace the connections of the h1,h2 pins there must be an open resistor on its path to the CRT socket..replace the resistor with the same value..The supply for the heater comes from the output voltage of the plyback..and so there is a possobility of plyback malfunction..try to replace them..tnx
    hope i help you....
    please vote for my help..
What's wrong with my LG 55LV9500 LED TV? Power on, black screen.
Hello, either the power supply is failing to power up the LED's or the LED strips in the screen have failed, a common issue with these sets. Power supply part # is EAY62169701. LED strips are only available as a complete screen assembly from LG....thanks
Apr 23, 2017 | LG Televison & Video
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
Why is my x201 lenovo thinkpad screen black. I am using an external monitor ok.
That means the connecting bus(cable) from the motherboard to the screen is damaged you can check it by opening slowly the screen of ur thinkpad if display comes at some place then the bus is damaged either replace that bus or the screen might be faulty you have to get replaced your thinkpad screen in this case
Jul 23, 2014 | IBM Lenovo ThinkPad X201 Notebook
Why does my toshiba satellie series a500 powers on but the screen goes black even though the computer is still running.
have you got devices plugged into the usb ports . Remove then try restarting Toshiba Satelite . My toshiba does the same thing if anything is plugged into the usb ports on boot up.
May 02, 2014 | Computers & Internet
Black screen
If the notebook is not displaying anything when powering on, but is still powering on (indicated by the power LED lighting up) then you should consider hooking it up to an external display or monitor to test where the problem stems from.
If, when hooked up, nothing displays on the monitor it is a hardware issue with the either the Hard Drive, System board, or LCD.
If, when hooked up, the screen displays normally on the monitor, it is an LCD problem
If, when hooked up, the screen displays with artifacting, vertical lines, or discoloring, it is an issue with the system board/ Graphics card.
Mar 15, 2011 | HP Pavilion dv2000t Notebook
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Hear power on, black screen. wont do anything.
- try to connect you machine to an external monitor
- if the display appears on your external monitor the problem would be the LCD screen of your laptop (need to replace it)
- if there is no display on both laptop and external monitor i suspected it's the motherboard faulty
- send your laptop to service center to replace it (if it is underr warranty it's free
May 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Samsung laptop black screen
Sounds like a loose connection between your mainboard, inverter or LCD. Try to connect an external monitor and see if the display appears to the external monitor. If a display appears on the external monitor, you need a qualified technician to check your laptop. I fixed 3 laptops with that same symptoms, 1 has loose connector, 1 has ground problem and the other is an inverter.
Apr 09, 2009 | Intel Motherboard
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
163 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
