I need to know what it is to purchase for my old goldstar cmt.9248 that will connect into my nintendo 64 control deck.
  • 149 Answers
Visit a electronic store and look for video to RF converter fry's electronics or radio shack
Posted on Apr 09, 2008
My n64 powers on but no picture
Nintendo 64 - Blank Screen Troubleshooting
Quick Tip: If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
  1. Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
  2. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  3. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Lightinstructions.
  4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
  5. Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Feb 25, 2014 | Nintendo 64 Console
N64 powers up but no sound or video
Quick Tip:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
Jan 04, 2013 | Nintendo 64 Console
My nintendo 64 is not showing up on my emerson tv
Quick Tip:
Aug 06, 2012 | Nintendo 64 Console
No video signal
  3. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
Oct 08, 2011 | Nintendo 64 Console
My nintendo 64 was working earlier on a different tv, but a hd one like mine, i have all the right cables and everything, i brought it back to my house from my nans earlier, and set it up, lights on so...
Quick Tip:
Jul 24, 2011 | Nintendo 64 Console
We have no manual - need instructions on how to hook it to the TV.
Nintendo 64 Hookups
Quick Tip! If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
The Stereo Audio/Video Cable that is included with the Nintendo 64 will allow you to connect the Control Deck to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have Audio/Video inputs . Though your TV may not have them, almost all VCRs do.
If you DO have AV inputs, choose where you want to connect to:
If you do NOT have AV inputs, you will need to use an RF Switch and RF Modulator for your hookup. The RF Switch and Modulator are sold separately. (Where to buy):
Connecting the RF Switch to a TV
Connecting the RF Switch to a VCR
Other Hookups
Feb 24, 2011 | Nintendo 64 Console
The red light comes on but the picture and sound doesn't show up. what do i do?
Quick Tip:
Quick Tip:
Feb 01, 2011 | Nintendo 64 Console
I can't seem to get my nintendo 64 connected. I've tried 3 different tvs and I got it to work for a short period of time today but it was not the game I wanted to play. After I turned the game off, I...
Nintendo 64 Power Problems
Make sure you are using a licensed AC Adapter (the system's power cord). The name Nintendo should be molded into the actual AC Adapter unit. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly. Also ensure all accessories connected to your system are licensed as well. (Expansion Pak, Controllers, Rumble Pak and Controller Pak.)
Make sure you are not using any game enhancing devices. Such devices are unlicensed and are not recommended by Nintendo, as they may not let your system function properly.
Firmly plug the AC Adapter into the AC Power Supply port on the back of the Control Deck and firmly plug the AC Adapter into the wall outlet.
Make sure your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
If it still does not work, you'll need to RESET the AC Adapter. To do this, remove all the accessories (including the Game Pak and all controllers) from the deck. Unplug the power supply from the wall outlet for at least 30 seconds, then plug it back in. If your system works without the Game Pak and controllers plugged in, there may be something defective with either the Game Pak or one of the accessories. Turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time to see if you can figure out which accessory may be in need of repair.
If these steps do not resolve the symptoms you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Nov 27, 2010 | Nintendo 64 Console
My nintendo 64 is like broken by every time no matter what i do my controller is plugged in and i turn it on and it says a controller is not connected please turn of your control deck and i do ive done...
Well its an internal problem with the console like the controller port might be broken or the motherboard of the console is messed up and needs to be fixed.
Aug 29, 2010 | Nintendo 64 Console
N64
Great clarification Nisha...
As with many other problems like this, check the input cable. it could be busted, and need to be replaced. Clean the contacts in the control deck, and in the cartridges.
Oct 22, 2008 | Nintendo 64 Console
Televison & Video Logo
Top Televison & Video Experts
