Question about Samsung DVD-V5600U DVD Player/VCR
Tuning vcr channels - Samsung DVD-V5600U DVD Player/VCR
    President:
  • 1,285 Answers
Do you have sat/cable the vcr is to be set to ch 3.....tuning vcr is to be set if you need/want to record a ch while watch another...go to menu and ch (auto tune)..this will search for all available ch...
Posted on Jun 27, 2010
VCR Recording OK but cant see tape content
VCR may not be tuned to the right channel. If you are using your VCR for the tuner then your tv is set to channel 3. Check your cabling again as well. From the wall to the VCR. From the VCR to the TV. You also need to make sure that you programmed the VCR for all of the channels. Just like you would for a TV.
Jan 20, 2013 | Panasonic Nv-Vp32 Dvd Vcr Combo 110-220...
Tip
Digitial channel tune in and set up
if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
on Aug 17, 2010 | Televison & Video
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
Sharp VCR hooked up to cable tv, i/p to vcr then out to tv.
I believe that I have the solution to that problem... When you are hooked up to cable or dish and use a VCR, you MUST have the program you wish to tape playing on the Cable or dish program, therefore the VCR needs to be tuned to channel 3 or 4 {whichever is the unused channel in your area) I believe that all you have to do is make sure that the TV is tuned to the channel you wish to tape and program the VCR to Channel 3 (at my area) or channel 4.
I hope this works for you. I have VCRs hooked up to all my sets and this is how mine work.
annabanana
Jan 23, 2009 | Televison & Video
How to tune to tv channels
There is a switch [tv-vcr] somewere in the front.When pressed to tv, you can change the channels FROM the vcr.You will need an "air wave" ANTENNA signal because the cable box individual channels cannot be seen when you place the switch to tv.Now if you have a cable box connected properly and turn that tv-vcr switch to vcr the individual CABLE BOX CHANNELS will show through the vcr.
p.s. There is a small switch (someware in the back of the vcr & the back of the cable box,dish box, etc., etc.) ch.3 or ch.4 and the VCR have to be on the same INPUT channel as the box.
Dec 09, 2008 | Televison & Video
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
I Am Having Trouble Tuning My Channels On My VCR.
Hey is the VCR set for cable? even if it's not a local channel
could try to come in. turn the blue screen off on the VCR that
might solve your problem. If the channel is weak the blue screen will come on and block it. you can turn it off by going into
your VCR settings. Also If the cable is weak a splitter will
cause this you might have to hook the cable up directly to the
VCR to record it and watch it through the VCR. that's was may
problem once.
also you can tune channel 12 to your VCR manually if it is too
weak because of a nearby local channel it won't tune in automatically.
Nov 12, 2007 | Sanyo VWM-800 VHS VCR
Programming panasonic vcr
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
Samsung DVD-V5600U DVD Player/VCR Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
