Question about Panasonic Lumix DMC-FX30 Digital Camera
The on/off switch on my Lumix DMC-FX30 has gone haywire. The lens wont retract when I switch off and it retracts when I switch on!
  • valentine_ho Jun 03, 2010
    You have not solved my problem. I put the switch in the off position and the lens comes out. I switch to the on position and the lens retracts and i get a message that I should switch the camera off and then on again. Meanwhile I cannot take pictures nor access the photos I have already taken.
    President:
  • 1,382 Answers
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Thank you !!
Posted on Jun 03, 2010
    I haven't dropped it and I've tried cleaning the battery
    Genius:
  • 1,040 Answers
Dear Valentine,
Don't worry.... it is a connection problem... It will not create any problem.... It is hardware problem. If u wanna to get it as early, then get it serviced..........
    It may well be a hardware problem but my camera doesn't work. You have not given me a solution.
Digital zoom won't retract fully
If you've powered on and off the device multiple times and it still won't retract it's likely the delicate mechanism that retracts the lens was damage. Generally that is not repairable...
Jul 03, 2014 | Panasonic Lumix DMC-FZ28 Digital Camera
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
Lens will only partially come out - a few mm - when powered up. It then retracts.
The lens is retracting because there is something preventing it from fully extending. It is a safety mechanism built into all digital compact cameras to be sure the lens doesn't force itself and break. Once it encounters resistance, it will retract.
Make sure there is no debris between the lens rings and try again. If the problem doesn't go away, you will likely need to take your camera in to be repaired.
Mar 05, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
It fell on ground lens wont fully retract grating sound
the sound ,becsz of damage of the parts of the lens mechanism,such as gears,guides and guide-pins,so get it serviced,replacing the damaged parts.
Mar 07, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
Jan 13, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
The lens is stuck
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Dec 31, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Panasonic Lumix DMC-FX30 Digital Camera Logo
74 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
