Question about Refrigerators
Transported the refrigerator on it's side and when we got to our destination, the ref doesn't work. doesn't get cold
  • 4,793 Answers
You should have let it"rest", upright for 24 hours before you switched it on to let any gas bubbles settle.leave it closed and hopefully it will go back to normal soon....
Posted on Jun 03, 2010
Freezer doesn't cool
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 26, 2011 | Samsung RS2530BWP (25 cu ft) Side by Side...
Kenmore side by side model 106.44109300 doesn't power up every time, freezer and refrigerator lights blink, unable to change refrigerator or freezer temperature settings, lock out light is off, quick...
NOTE: This
MORE TRICKS:
Leo Ponder
imufo2
Leo Ponder
Sep 24, 2011 | Kenmore Side by Side Refrigerator
Moved my mds2434ge maytag side by side from one house to another. it was unplugged for maybe a day and half. plugged it back in everything worked fine for about 30 minutes then the compressor stopped and...
NOTE: This
Leo Ponder
Aug 17, 2011 | Maytag MSD2434GE Side by Side Refrigerator
We moved our whirlpol gold refrigerator and now it won't work
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 14, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
WONDERING WHY MY GE GSS22SGRB SS REFIGERATOR ISN'T GETTING COLD, ALTHOUGH THE FREEZER SEEMS TO BE WORKING PROPERLY.
you should have a dial or knob that says freezer colder or warmer if so turn it for freezer to get warmer thast should allow cold aiur from freezer to enter into ref. that should make ref. colder. if to cold then dail it back a little at a time till ref. is what u like. ok try that. later gator.
Feb 15, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Freezer works fine,refrierator not cold.
Check to see if the fan is running in the frezzer side. This is called the evaperator fan and it blows the cold air from your evaperator to the ref side to cool it. If this is not running then your ref will not be cooling at all.
Jul 29, 2009 | Refrigerators
Freezer is cold but not freezing the ref is not cold
Simple! Refrigerent leak only results in poor cooling. Check your thermostate also to make double sure of the cause.
Jul 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ge profile buttom freezer cold refrigerator hot
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerator/freezer not staying cool
If there is no frost on the freezer side it may be low on coolant.
Dec 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
