My laptop cant find my wireless connection but finds other connections in range.I can only connect using ethernet cable from router.spoke to sky who said I need to contact acer as my laptop is not configured for the router even though I have used it for over a year without any problem
    Sergeant:
    Champion:
  • 293 Answers
Check your router configuration maybe the wireless is not open. you have to configure your wireless connection in your laptop to the router
Posted on Apr 09, 2008
  • 655 Answers
You might be blocked your SSID broadcast in your wireless router make it broadcat enabled then it will find your connection.
Your lap is ok and settings are well, b.coz it gets other signales. So just check your wireless AP settings.
Thanks
Iqbal
How I reset my router to the old password? And how can I use it without Ethernet cable
Hi
There is a wide range of help from here:-
http://www.skyuser.co.uk/forum/tags/dsl2640s.html
but generally resetting to the old password requires access to the router settings. It is often easier to go back to the original settings by using the reset button.
To use the router without the Ethernet cable, you need to set up the wireless settings within the router and then connect using your computer's wireless connection.
If your computer does not have wireless capability, be it laptop or desktop, then you will not be able to connect to the router without an ethernet cable.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Apr 09, 2015 | Computers & Internet
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Can I use USB Cable direct to laptop from modem? Ethernet cable from modem is connected to router which is connected to desk top PC. OR should I connect a ethernet cable from router to laptop? Type of...
Hi Friend, It depends that whether your router is wireless or wired. If it is a wireless router then there is no need to connect the laptop with the cable, you can use the laptop wirelessly If it is a wired router and as you said that the Desktop is already connected to the router with the cable so in that case you have to get another ethernet cable and can connect it from the router to your laptop
Dec 08, 2010 | Computers & Internet
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Connection problems using ethernet cable
your modem or router has othere lan port or not if there then put it and in laptop you using dhcp or by manually given ip address what is that you have to give the same in the desktop and pls off the firewall of the desktop computer
Jun 02, 2009 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
David Payne
David Payne
