Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I have purchased amana international model srd 522 sit w in 1995 for india. The compressor is dead which was 110-115 volt. Can i get a replacement. The compressor make was Techumseh TP 1930, In india, it is only available 220 volt and not 110 volt can i get TP 1930 compressor of 110-115 volt 50-60 cycle
  • Anonymous Mar 30, 2014
    amana compressor model: SBD522VE MFG NO P 1320303WE compressor made in brazil TP 102JR003A8
    I need the compressor for 220 volt
    Director Badge:
    Uploaded 100 video answers.
  • Amana Master
  • 489 Answers
You can find out what will be replacement part number in any HVAC/R supply store. This is how bad compressor looks like inside.
Posted on Jun 12, 2016
  • Amana Master
  • 4,655 Answers
What you need to do with a burned out compressor is throw the refrigerator away. When compressors burn out they contaminate the sealed parts with acidic smoke that if replaced with new compressor would damage it in a few hours. Yes you can find a compressor that is 220 volt/115 volt @ 50 cycles. If you know for sure the compressor is a burnout I would not change compressor, Thanks and good luck, Sea Breeze
Posted on Jun 03, 2010
SOURCE:
Why does my new motor trend power house jump starter with air compressor not take a charge from the a.c. or d.c. charger?
Contact manufacturer. If still under warranty they should replace. Sounds like the internal battery is dead...there has to be a little "juice" left in the battery for the charger to have a complete circuit to charge...some of these units take 24 or more hours on an initial charge.
Hope this helps,Ron
Nov 30, 2014 | Power Center Jumpstart 11-411
Amana upright frost free freezer, early 1970's vintage
For the love of God get rid of this death trap.
It could be that it was meant to have a neutral earth, ie the neutral is connected to earth at the substation and house inlet and somehow the live and neutral has become reversed at the plug.
You have seen the case becomes live, this may be happening due to leakage current or a short as you say.
Either way the earth was there for a reason, to stop the case from becoming dangerous and you have removed that protection.
Neither the heater element or motor windings should have continuity to the case, I'd disconnect and check these out individually to isolate the problem and repair it, then put the earth connection back before using the freezer.
Oct 29, 2007 | Freezers
Amana Ptac model PTC153B50AM, getting no heat
The heater relays on the circuit board are famous for going out in this model.. Can purchase circuit board for about $100 or individual relays for about $4. Have to solder them in.
Nov 13, 2013 | Amana PTC153B50AM Split System Air...
Need a filter for Amanda SRD 522 TW which one do I need.
http://parts.sears.com/partsdirect/part-model/SRD%20522%20TW?shdMod=SRD+522+TW
you need the additional mfg number to help refine your search. use that link and pick one of the two which matches yours. then search for a filter and you can order it from there.
Aug 05, 2013 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Please how can i get a part for amana frige freezer model no srd 528 uw and serial no 9905167491
Try repairClinic.com . They carry a large selection of repair parts with detailed installation instructions. You'll need your model #, serial #, and year of manufacture.
Jan 04, 2011 | Amana Refrigerators
I purchased an Amana refrigerator that has been making a humming noise and will not keep food cold or frozen. what' wrong? The model # is ABB1924DEB, and I purchsed it in 2005. is it included in their...
The recall was for units that had embraco compressors. the relay would burn up and not start the comperssor. (hum and click) some amanas had tecumseh compressors. They would just scize up and not run (hum and click)No recall. remove the back cover and see what name is on your compressor. If its hot and trying to start, Embraco needs new relay, Tecumseh needs to be replaced with a embraco compressor.
Dec 01, 2009 | Refrigerators
My Amana fridge (model ARSE67RBB) compressor has stopped working. It locks up when it gets too hot, and then makes a high pitched buzzing sound. I purchased the fridge used, so I don't think Amana is...
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Oct 30, 2009 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Can i use an Xbox 360 bought in USA in India - given the voltage conversion required? would there be any seperate adaptor available for 220 volt usage in India
You can purchase a volt adapter (rather common in travel stores/airports) but over time the device's power-supply will wear out because of the frequency difference.
North America runs at 60hz
India runs at 50hz
Jun 30, 2009 | Microsoft Xbox 360 Console
Refrigerator compressor going
that's a good fridge i wood fix it if under 450.00
Apr 22, 2009 | Refrigerators
Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Dec 15, 2007 | Amana ARSE66MB Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
268 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
