Question about Janome Sewing Machines
Stop Motion Knob stuck?
How can I loosen the stop motion knob to wind a bobbin? I have the Janome Threadbanger TB-12 sewing machine
3 Suggested Answers
  • 323 Answers
SOURCE: Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
Posted on Sep 03, 2008
  • 92 Answers
SOURCE: I cannot loosen stop motion
Sometimes the knob locks so tight it requires a good strong beefy man to loosen it. Turn it counter clockwise!! You can also wind without loosening the knob, just MAKE SURE to unthread the machine and to sew for winding only. It works for all industrial machines, without loosening the knob.
Derek
Posted on Jan 15, 2011
Why won't the motion stop knob will not move?
Look carefully for thread caught around and under the knob. If you can't get it to turn and find no reason why it won't, you can probably delay fixing it until the next time it's due for its yearly "tuneup" (COA, clean/oil/lubricate) by taking the needle out before you wind a bobbin.
Jun 02, 2014 | Husqvarna Husky 145
Stop motion knob will not disengage the needle when winding a bobbin
The stop motion knob on most older sewing machines is very much the same. You should find a small screw on the face of the knob. Loosen this but don't take it all the way out, it is real easy to lose and hard to find a replacement. Loosen it until you can turn the knob counterclockwise past the stop. Now remove the knob and there will be funny shaped washer underneath. Pay attention to how it goes on, you will have to put it back the same way.
Now to the "why" of your problem. The assembly has run dry, no oil, and the hand wheel should turn freely on the center shaft. You may be able to get some oil in with no problem or you may have to remove the motor belt to remove the hand wheel.
I find this a lot on old machines, nothing broken, just no oil.
Good luck,
Bob
Feb 05, 2014 | Montgomery Ward Sewing Machines
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
I cannot loosen stop motion knob so that I can wind a bobbin.
Derek
Jan 15, 2011 | Brother Sewing Machines
I turned the stop motion knob in order to wind a bobbin and the knob fell off! I have tried to put in back together but now only the knob will move not the balance wheel. As as result the clutch will not...
There should be a washer that fits over the balance wheel, if you dont put that back on the machine wont work.
Check around and see if it fell off when you removed the knob, or check to see if it is stuck inside the knob.
The washer is about 1" in diameter with a couple little tabs on it.
It will only work when installed correctly so if at first you fail just turn the ****** over!
Aug 26, 2010 | Janome L-344 Mechanical Sewing Machine
Brother sewing machine
I have only a cheap one (VX-1100), but when this is happening on mine, the stop-motion knob isn't fully engaged with the balance wheel. They are held together by one being tightened to the other for sewing, loosened for bobbin winding. Michael
Aug 31, 2008 | Sewing Machines
Sewing Machines Logo
170 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
