Question about LaCie Computers & Internet
My Portable hard drive will only work on 1 computer
1. The hard drive installed no problem on my lap top running Vista windows. when i plug the portable hard drive into another computer the drive isn't reconised. I have tried this on two other client computers and the portable drive does not appear in my computer. I must be able to work some how?????
can anyone help me??????
2. I run my own accountancy business, working on my laptop last night ,I spilled wine on my lap top key board. won't switch on now is it knacked??
or is there still hope????
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Jun 03, 2010
Drivers missing for portable apollo 70GB hard drive
External hard drives do not require any extra device drivers to be installed. Any version of Windows XP, Vista , Windows 7 or Windows 8 will automatically detect the hard drive when you plug it in - no drivers required!
May 05, 2013 | Computers & Internet
How do i retriev my stuff of it to put on computer?
Assuming the harddrive is working, plug it in and click start and my computer( or computer if you are running vista or 7) and then in this window click the name of the harddrive. Then drag and drop?
If you used 3rd party software to back up your data you will need to install that first and run the recovery option
May 02, 2010 | Western Digital WD Passport 250GB Portable...
I have windows Vista. What do I have to do to install the portable drive? The instructions say open it in "my computer" and double-click on the "click here to start" file, but when I open it there isn't a...
Please confirm that the drive is indeed plugged into the computer via a USB slot. If so, the installation process should be automatic via Plug n' Play.
When you plug in a removable drive, it generally appears as a new drive in My Computer. For instance, your system drive is C:\ while CD/DVD drives will generally be D:\. In that case, your portable hard-drive will probably be E:\ or a letter further down the alphabet. It doesn't hurt to try opening each drive listed in My Computer. Since you haven't used the portable hard-drive, it should be completely empty (no files or folders inside).
If you can't find it, perhaps security software is interfering. Try disabling any security software you might have installed then plugging in the drive. Afterward go to My Computer and follow the same method outlined above of opening each drive looking for one that is empty or has a few files in it that you've never seen before.
Let me know if I can help you further. However, as mentioned, Windows Vista should install the drive automatically. Afterward you simply have to find it in, "My Computer."
Dec 29, 2009 | SimpleTech Signature Mini 250GB External...
WD Elements external hard drive not recognized/can't be found
ur vista version has a problem with usb portable devices so either u have to upgrade ur vista to the latest on or install windows 7 or down grade ur laptop and install windows xp
Jul 27, 2009 | Computers & Internet
Installing XP over vista
if your asking to install XP on top of vista.. if you do not like vista, then ur listening to your friends who have no idea what their talking about because its awesome and when windows 7 comes out youll be stunned...this is verry easy if you have XP disc ready, restart your computer you need to wipe ur hard drive to get rid of the old operating system, first save any thing you want thus wiping hard drive saves nothing.... techniquly its still there but ya....put in disc of XP and run the disc to install XP,. ACTIVATE IT AND WALA
Apr 22, 2009 | Toshiba Satellite® A205-S5841 PC Notebook
Lap top will not boot correctly when not connected to ext hard dr
First u check the laptop Display
if it has display, thn it might be problem ur windows
instead of it.
if computer does not give display thn u check the power adopter of ur laptop.
after all gonig through these steps.even u find all these above steps perfect.
it will mean,
it might be problem of ur hardware.
lets check out it by ur computer vendor.
Thanks
Danish khan
Feb 01, 2009 | Western Digital My Book Essential Edition...
I am trying to install a WD 250GB Passort V2 External USB 2.0 - 2-50" Portable Hard Drive but unfortunately my Windows XP doesn't want to know it. I have had it just over a week now and when I first...
Did you try a different usb port? is the cable plugged in correctly? check device manager and monitor it once the ext. hdd is plugged and report back with the result plz.
Jun 16, 2008 | Computers & Internet
Photosmart 3310 is on network but not recognized wirelessly
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
Hope this helps.
Dec 25, 2007 | HP Photosmart 3310 Printer
Nexxtech 3.5" Hard Drive Enclosure (NHDE35)
I'm not saying this will solve all problems, but it solved it for me. I am running Vista and got this to work following someone's instructions from another forum.
The slot in the enclosure that you plug the hard drive into has one set of holes fewer than the hard drive has pins. This means you can plug the hard drive in two ways "left" and "right" if you will. I had to plug my hard drive in so that the unused pins were farthest from the power cable that plugs into the hard drive.
Incidentally this made the screw holes line up better, too.
Oct 01, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Computers & Internet Logo
98 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
