Question about Nokia 6111 Cellular Phone
On and off when the sim is inserted.. if has no sim my mobile is functioning.. how can i fixed it?
  • Nokia Master
  • 624 Answers
Your phone needs to reprogram
Posted on Jun 07, 2010
HELO!PLEASE CAN I GET A HELP? MY LUMIA521 CAN'T READ SIM CARD.
Remove back cover and remove battery and check sim is properly fixed in side sim slot or not. If sim is loose inside sim slot then put some paper packing make it properly fixed also remove sim and rub with cotten lock the golden part of the sim and insert again. Also check the sim in another mobile and if in that mobile sim also not recognized then there is issue with your sim card replace it.
here is how to sim unlock mobile http://mobile-cellphones.blogspot.com/2016/06/android-smartphone-sim-unlocking-details.html
Jul 21, 2017 | Cell Phones
My stc sim card not functioning. It say "mobile network not available " What should I do to fix this problem? Anyway this is my number.. (0509265369) Thanks
First remove your sim card, and wipe it care fully with lint free cloth peace, and clean slot also with close blow with your mouth on it, and wipe it as well, then insert sim card in again, I hope it will work, mine worked. Thanks
Jan 02, 2016 | Cell Phones
I put my sim card in my phone and it says please insert sim and my sim card is in the phone how can i fix it
Some manual solution to bypass insert sim message on your mobile phone.
1.There may be a problem in your Sim card so try another one.
2.Check your Sim whether it's properly inserted or not
3.Your mobile is locked to particular network provider.
If your problem persists after trying the first two steps means,Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit Unlock-Zone.com and you can get free phone unlock instructions from
MobileUnlockGuide.com
May 01, 2014 | HTC Inspire 4G Smartphone
Insert sim card 5320
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Nokia shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Nokia 5320. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Theunlockarena.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Jul 24, 2013 | RIM Cell Phones
Insert sim
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Samsung shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Samsung B5310. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
Jul 21, 2013 | Samsung B5310 Cell Phone
Sim not function
Have you inserted a valid SIM card? what is the problem? when you insert you Sim into your mobile do you any of the message like this "Enter Restriction Code or Enter Unlock Code" if so your mobile is locked to your current network and unless otherwise you unlock it,you cannot use your mobile with other provider's sim in your contracted mobile..you can unlock your mobile by unlock codes and for codes you can contact your provider or can get it from online providers..once i got unlock code for my mobile from mobileunlocksolutions and unlocked my mobile..you can too try getting codes from them and get your mobile unlocked..and before unlocking your mobile get clear idea about unlocking procedure..visit mobileunlockguide to get step by step instructions about unlocking your mobile..
Aug 09, 2011 | Nokia 2730 Cell Phone
Ask to insert sim card
Hi nixora2002,
This means that inorder for the phone to function properly you need to have a sim card, then insert it to the mobile phone so that you can call and have proper function of over all use.
I hope this helps.
May 23, 2011 | Nokia 6070 Cellular Phone
I got msg display insert sim even after i insert it..could u rescue me
check the sim on other mobilewhether it is functioning or not? if it is working then try to clean the sim bracket where it is inserted in the mobile and try it again. alternatively try some other sim on your mobile
Sep 07, 2010 | Sony Ericsson K530i Cellular Phone
Nokia 6111 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
