Question about Mitsubishi LT-52249 LCD TV
The picture on my Mitsubishi LT-52249 is too big for the screen. How do I fix this?
3 Suggested Answers
  • 668 Answers
SOURCE: My Mitsubishi LT-52249 television's audio and
I have seen issues like this on other manufactures sets needing a software up grade. Mitsubishi deals one on one with customers with software upgrades and will usually send out a SD card with the upgrade on it. This is their customer service number. 1800-332-2119
I hope this helps,
Skyassoc
Posted on Dec 10, 2010
  • 302 Answers
SOURCE: No audio in my Mitsubushi LT-52249...
Your signal board is proably bad and will need replacing.
You can get parts at www.interliquidparts.com
Posted on Dec 16, 2011
Where is fuse location?
Can be located at the SMPS [Power Regulator] board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 11, 2015 | Mitsubishi LT-52249 LCD TV
Mitsubishi LT-52249 continuous blinking green light wont pwer on/off
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Electro help
Jan 07, 2014 | Mitsubishi LT-52249 LCD TV
Mitsubishi model LT-52249 picture is green
A plain green screen indicates mostly a to a panel fault. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Screen-shots to defective LCD panels are given. Compare it to that of your TVs' and make sure about the fault. Surf the site.
Nov 02, 2013 | LG 42LC2D 42 in. LCD HDTV
Green light constantly blinking and tv screen doesnt turn on
Good day!!!
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
  1. Open the back cover.
  2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
  3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
  4. If the power supply output is normal..The problem could be on the main board...
  5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
  6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Oct 13, 2012 | Mitsubishi LT-52249 LCD TV
Is no audio a propblem that is repairable?
Hi hve you checked your setting on your tv. Check to make sure your speakers were not turn off. Try doing a system reset. IF that 's not the problem you might hae a problem with your sysnal board was there a storm or a power failure that might have caused the problem. Hope this helps.
Dec 02, 2011 | Mitsubishi LT-52249 LCD TV
My Mitsubishi LT-52249 television's audio and video become unsychronized after a period of several hours. I have to unplug the set to resynchronize. Any thoughts on what would cause this?
I hope this helps,
Skyassoc
Dec 10, 2010 | Mitsubishi LT-52249 LCD TV
The picture on my Mitsubishi rear projection big screen has pink and green lines going around all of the images
you will need to ajust the convergence of your tv. there should be a "test" swich/feature that brings up a grid on the screen. ajust the horizontal and vertical of each of the colors until the lines become white. you will need to be more specific on which model you have if you need more detailed instructions. it should cost less than $75 to get a tecnician to come over to fix this.
Aug 08, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Mitsubishi LT-52249 LCD TV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
