Question about Electrolux Dishwashers
Where does the spring go int the handle for the dishlex supreme. How does it go in?
  • 159 Answers
You need to disassemble the panel with the handle in it in order to see where it goes,there is normally 2 springs depending on the model you have.
Posted on Jun 04, 2010
1995 Oldsmobile Cutlass Supreme - Exterior door handle is unresponsive (no tension or snapback). Interior still works fine. any suggestions?
a few things,1- the retainer clip came off 2-the spring came off 3- the clip on the handle that holds these components broke,either way the only way to find out is to remove the door panel for further inspection.
Feb 02, 2015 | 1995 Oldsmobile Cutlass Supreme
Why door will not latch close on 103 dishlex dishwasher ?
Check whether the dishes are touching the door before closing the door..Or the spring mechanism of the latch is damaged
Jul 06, 2014 | Microwave Ovens
I have a dishlex 300 and when i open the door it just drops down could this be something with the spring or hinges in the door
tHE DOOR SPRINGS ARE BROKEN. IF YOU HAVE DROPPED THE DOOR TOO MANY TIMES THE HINGES MIGHT BE BENT TOO. yOU WILL PROBABLY NEED HINGES AND SPRINGS....A bit of a job for a novice....like my capitals sorry about that.......
Mar 01, 2011 | Dishwashers
Need a transverse spring for 1194 cutlass supreme
that's what most people call it, go to the local salvage yard get one off a 92-93-94 olds, chev luminia
Mar 17, 2010 | 1995 Oldsmobile Cutlass Supreme
I have a 1994 olds cutlass supreme and there is a switch located below the headlight switch. What does it control ?
Under the headlight switch there a switch, it reads
Panel Light - Dim - Bright - Int
That's for your cluster light's where your gauges are at.
Feb 03, 2010 | 1994 Oldsmobile Cutlass Supreme
How to strip down a pflueger supreme reel. i need to know how to undo the handle from my pflueger supreme reel so i can get the side cover off. i need to change the pawl, and the pawl axle
On the new Pflueger Supreme ( which I own one of) tighten the drag down ( just snug it down) PUSH IN ON THE DRAG STAR, TURN HANDLE; COUNTER CLOCK WISE! Handle will back off...you must keep the drag star compressed until you reach a point it will no longer engage.....DO NOT LOSE THE SPRING behind the drag star. Good Luck.
Jan 08, 2010 | Shakespeare Sport & Outdoor - Others
1993 Cutlass Supreme S 4 door sedan Drivers side front door locked when door was open, the locking mechanism is stuck is stuck and the door can not be closed. How can this be fixedd?
take a screwdriver and put in gap of mechanism and apply pressure while lifting door handle the latch should open if it falls back means spring is broken on latch will need to remove door panel and the 3 screws that hold it in place can get a replacement at a salvage yard for a few bucks
Dec 14, 2009 | 1993 Oldsmobile Cutlass Supreme
When I installed my delta replacement cartridges, RP1740 two handeled faucet, the water will not turn off no matter which way I turn the handle. I have a new rubber cup and spring. It looks so easy, I must...
Sounds like you might have the rubber cup seals installed upside down? The spring goes int he body first, then the cup seal goes over and on top of the spring.
Jun 25, 2009 | Delta Plumbing
Bought a house with a Dishlex Supreme Deluxe Dishwasher already installed. It's an older model 8574 and we have no manual. Is it possible to get one somewhere?
Not sure if a manual would still be available but I can tell you that the Dishlex washer was made by Vulcan / Electrolux and was originally sold in Australia. You may want to check eBay Australia or some other online resources from down under! G’day mate!
Apr 01, 2008 | Dishwashers
Dishwashers Logo
85 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
