Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
How to cofigure d link modem..
Confugration of boud rate ...
want to have boud rate 9600 ....
  • 46 Answers
Configuration/Initialization String
Using a straight through cable and a PC or dumb terminal, enter the following string into the modem.
type in: at <cr>
modem responds with:OK
type in: at&F &B1 &A3 &I3 &S1 S13=1 &W0
modem responds with: OK
Posted on Jun 04, 2010
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
How to change boud rate from 19200 to 9600
Here are the complete steps to change your LX-300 bit rate to 9600.
1) Load a paper with the friction lever up.
2) Hold the FONT button and switch on the printer. The printer must sense the loaded paper and must start printing some stuff. If not it rolls and tries to load the paper. In such case insert the paper again and press PAUSE button. Now the printer will print the stuff i.e) the current printer settings.
3) After the printing finishes (the print matter will be around 25% of a 11inch page length), press LF/FF. You will find the current settings. Check the current bit rate which is indicated in the 10th line of the current settings table.
4) Now press LF/FF which takes you to the Table B.
5) Now you are in table B and the lights 1, 2 and pause must be Blinking, Off, Off conditions respectively.
6) Now press the FONT button 9 times. After pressing FONT nine times, Light 1 = Blinking : Light 2 : Blinking : Pause light : ON.
This means that you are in Bit rate menu now.
7) Press PAUSE button.
8) Note down this order of bit rate and the status of 1, 2 and Pause lights.
--300 = ON-OFF-OFF
--600 = OFF-ON-OFF
--1200 = ON-ON-OFF
--2400 = OFF-OFF-ON
--4800 = ON-OFF-ON
--9600 = OFF-ON-ON
--19200 = ON-ON-ON
From the current bit rate you are in now, press the FONT button a particular number of times accordingly.
Suppose you are in 1200 bit rate currently, the lights status will be ON-ON-OFF. If you want to set to 9600 you have to press FONT button 3 times and the lights status change to OFF-ON-ON , which indicates 9600 bit rate.
9) Now, press PAUSE button so that the settings get saved.
10) Switch off the printer and turn it back on after 20 seconds.
11) Switch it off again, Hold the FONT button and switch it in again.
12) After printing finishes, press LF/FF and check the bit rate in the current settings that is printed.
You can have the user manual for your reference.
files.support.epson.com/pdf/lx300_/lx300_u1.pdf
Thats' it. You're done!
regards,
Sabharish
Sep 30, 2009 | Epson LX-300 Matrix Printer
What is the hot key to make the switch between computers
Since your KVM is a Belkin, the answer to your question can be found at the link below, on pages 9 and 10 of the PDF.
http://cache-www.belkin.com/support/dl/f1dl102p.pdf
Aug 26, 2009 | Belkin Computers & Internet
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
I have my fax machine hooked up through a magic jack. how do i change fax speed?
I contacted the folks at MagicJack today and for faxes they confirm your findings. They suggest the following: We do not officially support using faxing with MagicJack. Please try the following steps to use MagicJack with your fax (contact your fax vendor for details):
- turn off error correction on your fax machine or program
- set the fax machine or program to use the slowest speed available
- increase the speed, checking at each speed that faxes work
The change must come through your fax machine, not the MJ.
HERE is a link to the manual for your fax machine.
If you are having problems sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the Equalization for compatibility to
reduce the modem speed for fax operations.
a Press Menu, 2, 0, 2.
b Press a or b to choose Normal (or
Basic).
�� Basic reduces the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
�� Normal sets the modem speed at
14400 bps. (Default)
Press OK.
c Press Stop/Exit.
Note
When you change the compatibility to
Basic, the ECM feature is only available
for color fax sending.
There are only 2 speed settings. Since the MJ does not support faxing, if the slower 9600 bps does not work, you will be unable to fax with the MJ.
Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | Brother Multi-Function Center MFC-240C...
Manual
Hi - You can download the manual from the link underlined in blue below:
MFC 9600
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Brother MFC 9600 All-In-One Laser Printer
Baud rate
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
and MFC-7225 only.
Note
14400 bps.
33600 bps.
May 28, 2008 | Brother IntelliFax-2820 Laser Fax
I want to use my WAP to share my internet connection.
i have motorola wa849g.i reset now i want to cofigure this i open explorer put 192.168.10.1 didnot open show page canot open
May 22, 2008 | Arris WA840G 802.11g/b (49832000100)...
Baud rate
that's in fax settings...you can choose as much as your modem has inside..
no worries, check for up to date printer drivers here
Jan 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
136 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
