Question about Avanti WC5100BG Wine Cooler
The wine bottles in my wine chiller are covered with what appears to be a white and or black mold. The bottles have been in the chiller for about 3 years. Is this normal? Some of the lables are falling off and the bottles look like **** with the mold. What should I do?
  • Anonymous Mar 19, 2014
    My wine chiller stays at a reading of 59F 24/7 even though i have lowered the temperature to it's lowest setting which is 34F.
  • 4,793 Answers
Put a dehimidifier/silica gel sack in the bottom to keep the interior dry.dont forget to oven dry the silica gel every month.
Posted on Jun 03, 2010
Testimonial: "Thank you. I hadn't thought of silica to dry it out but I will try it right away. I really appreciate your suggestion@"
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
Is there such thing as a single bottle wine cooler?
Of course! There is a wide variety of single cooling systems for wine bottles. We don't drink a lot of wine, but when we have guests over I like to have the wine chilled properly. I prefer the stainless steel coolers, since the look more sleek and stylish.
http://www.amazon.com/Vinotemp-VT-CHILLER-SLVR-Bottle-Chiller/dp/B001NFX2QU
http://www.polyvore.com/danby_maitre_single-bottle_wine_chiller/thing?id=541026
Jul 31, 2012 | Furniture
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
Jan 16, 2009 | Kitchen Selectives CM-202 Coffee Maker
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Avanti WC5100BG Wine Cooler Logo
251 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
