Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Tosh 40pw8db
By capp_man on Apr 09, 2008
hi i turned up the screen all i see is wavey red green blue line not moving, there are 2 big chips STK392-110 IS THIS THE PROBLEM, I ALSO HAVE A ANOTHER CHASSIS NOT THE SAME, IT HAS 2 STK392- 010 CHIPS ARE THESE INTERCHANGABLE. REGARDS MARK, ALSO IS THERE A PROTECTION RESISTER OR FUSE FOR THOSE CHIPS, REGARDS AGAIN MARK
Comments:
Apr 09, 2008
- hi bill after a lot of thinking, not so much testing, i thought back to a std TV and the systom was of field collapse, my brain not being what it was, it didnt think a 3 tube projetection tv would suffer from this, turns out the IC LA7833 was at fault, i left the tv on for an hour, then turned it off all heatsinks were hot or warm, cept the one that had LA7833 attached, so i changed it, bingo.Maybe i was just lucky on this one, the pictures not all that good, sightly yellow tint on the left blueish tint on the right, not very bright, but ok ish,convergence is out on the right too, i have no remote, so i cant make adjustments, oh well, thanks for your help, regards Mark.
Same Problem
Aug 19, 2008
-   Hi,
I just had the STI392-150 ICs replaced, but my remote control stop working. The manual convergence on the menu doesn't allow me to access. What have I done wrong? My TV is 57H81 toshiba.
Thanks,.-   cu22cm22
Best Solution
posted on Apr 09, 2008
Helpful)
premtech
Rank: Guru
Rating: 89%, 1235 votes
(1) The STK392-110 are the convergence amps, (2) they are not interchangeable with STK392-010 but you could use STK392-150 or 180 for greater reliability. They are merely the same Ic with greater amperage. (3) Yes, there are several low ohm resistors in the return circuit, out front of the convergence amps. Using an analog or digital meter test them for open or change in value and replace as needed.
Bill
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS... (More)
Answer
Whenever I turn on my TV, The Menu automatically comes on and no matter what i do, it never come... (More)
Answer
We have a 2002 projection Hitachi TV and the colors are not lining up, ex. greens too far left,... (More)
Answer
We have a 36" RCA Home Theater Premeire TV that does not have a alarm to turn TV on but the TV... (More)
Describe your Projection Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
