Question about Pioneer VSX-D511 Receiver
I have a Pioneer VSX-D511 that is malfunctioning ..... when I plug it in I get an "amp error" message on the display and then it shuts off! what's wrong with it?
    President:
  • Pioneer Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
How do I fix the amp error?
there is probably a short in the amp.. One of the amp ic's is shorted and rpobably took out a couple resistors as well.
Jul 21, 2014 | Pioneer VSX-D511 Receiver
PIONEER AMP ERROR
Most probably you have one of the power amplifier modules bad. They are the PAC010 and PAC011 type. You can remove one and power up the receiver. If it powers-up normaly it's that one.... (50% chance) Otherwise remove both and it should power up normally. Beware that these parts are expensive... Most times just with a new part the problem is solved. YMMV. Good luck
Jul 14, 2009 | Pioneer VSX-D510 Receiver
Pioneer VSX-D511 Comes up with AMP ERROR and shuts down
I must agree that if the fuses are open and you replace them that your problem maybe fixed. If you can remove the fuse, I recommend taking it to a RadioShack and see if someone there can figure out what it is. I am going to assume that the fuse should be a 250 V. If you can find one that matches the same appearance, go with the smallest aperage rating you can find. Go with this route only if the person can not tell you exactly what it is you need. Be sure to match the type of fuse if you can see inside it like in the case of a glass fuse. Some are slow-blow fuses and some are fast-blow. If you are uncertain your safest bet is to use a fast-blow with a real low amp rating for the voltage you are using. If the amp rating is too low, it may run fine at lower volumes and pop when you turn it up. If I could physically see the fuse, I would probably be able to tell you what it was and what you needed to replace it with.
Jun 06, 2009 | Pioneer VSX-D511 Receiver
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Dec 28, 2008 | Pioneer VSX-D411 Receiver
Pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Sep 08, 2008 | Pioneer VSX-D511 Receiver
PIoneer VSX-D510 power issue! pleas help!
Must be the protection circuits kicking in. One or more amp channels must have blown.
Feb 01, 2008 | Pioneer VSX-D511 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Pioneer VSX-D511 Receiver Logo
237 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
