Question about Dryers
Dryer cloths are getting stuck between drum and inside front where drum and inside frot meet can it be fixed is it worth repairing
  • Anonymous Aug 07, 2008
    HAVE FRIGIDAIRE WITH SAME PROBLEM. RUINING CLOTHES OR GETTING CAUGHT BETWEEN DRUM AND OUTSIDE OF FRAME. SEEMS TO BE DESIGN FLAW. I CAN'T SEE ANY SOLUTION, AM READY TO BUY NEW DRYER SO DISGUSTED. OTHERWISE IN PERFECT CONDITION. DRUM IS NOT LOOSE OR UNBALANCED, AND I DON'T OVERLOAD. ANY HELP?
    Genius:
  • 1,073 Answers
Brand and model will help
Posted on Apr 10, 2008
Drum in Amana dryer has dropped leaving a gap on back wall at bottom where it meets drum. clothes get torn & marked. How do I access & fix?
Tumble drier drum bearings are often nothing more than strips of felt stuck or clipped onto a pressed steel flange or a similar simple idea. They give good service but don't last forever and eventually metal-to-metal contact happens and if repairs are neglected the steel flanges are also worn away and the drum begins to tilt...
I have fitted several felt bearing kits and twice have needed to weld in some steel to restore a flange.
The job usually entails almost completely dismantling the casing.
May 30, 2016 | Amana Dryers
I have a Frigidaire front load dryer that makes a very load squeeky thumping sound like there is something heavy in there tumbling... also my clothes get stuck in between the drum and frame of the dryer...
Broken wheel or wheels the drum turns on. Not to difficult to fix. Both RepairClinic.com and appliancepartspros.com have videos to show u how good luck
Mar 05, 2015 | Frigidaire Dryers
Hotpoint aquarius vtd00 dryer clothes getting stuck all the time how do I fix
hiis the rim of the drum seating ok or worn out because it will give u sharp edges its all i can think of take top off rotate by hand check rim allso try lifting drum if you have fair bit of play you need front bearing pads
Dec 28, 2013 | Hotpoint Dryers
The inside back & drum meets clothes getting stuck
sounds like one or more of the rollers the drum rides on has moved or is broken, using a putty knife slide it between the top and the front panels on each side to release the top of machine open it up like a car hood, the front of machine has clips holding it to the sides remove the front for access to the bottom of drum where rollers are, it should be obvious where the rollers are supposed to ride check for loose broken mounts, unit will snap back together
Jul 04, 2012 | Maytag Dryers
Everything gets caught in the front crack where the drum ends by
The glides on the inside of the front door are worn, possibly the felt too. You'll have to remove the front of the dryer to see the problem and fix it. Mine did the same thing. Because they are worn the drum is at an angle allowing a gap to form where the clothes get stuck.
Jun 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Dryer leaving black marks on clothes
Depends on age..its the bearings that gone, normally a felt bearing seal the drum and wears after about 4 yrs.parts cost about.£18..plus labour..so you decide. please leave feedback
Apr 07, 2010 | Dryers
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
I have a Maytag Dryer MDE9806AYW Intelli Dry SQUEALS
Yes its worth repairing, it sounds like a simple fix, could be pulley, or seal replacement but for the price of some machine oil, or part, well worth it. The intelli dry pulls apart from front, with the door and top is hinged. A little time consumeing but I think still worth it.
Feb 04, 2009 | GE DBSR453EBWW Electric Dryer
Marked clothes
probably needs a new front drum seal what is the model#?? Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Sep 30, 2007 | Kenmore 63942 Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
