Question about Nokia 1208 Cellular Phone
1208 not charging problem - Nokia 1208 Cellular Phone
Nokia 1208 enter puk code
Hi, you can unlock it from (www.wickedunlock.com) very quickly and easily Note: unlocking is not free, You will be charged to get your unlock code. The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code.(you can use any of your friend's phone to make this call) If your service provider refuses to give it to you, then there is no other place where you can get a free unlock code. GoodLuck =)
Jul 28, 2011 | Nokia 1208 Cellular Phone
Please give me the nokia 1208 chargin way
Mobile Solution for 1208,schematic and charging ways.
Basic steps to check before doing hardware modification.
* check the charger if it's OK
* Check the charging pin. usually, + pins (center) are broken
* clean the charging interface in the mainboard PBC
* battery might one of the reason why charging is not possible,so better test another one.
Good luck...Thanks for visiting FixYa...
Jul 11, 2011 | Nokia 1208 Cellular Phone
I have a nokia1208 mobile and now its dad ;;;;; i checked this and supply has reached at on /off switch but is not getting on''''''''so plz tell me any soluion how can i...
Check the battery ! it must have been out of charge.. charge your cell for about 1 hour, and start the phone. If it does'nt, make it checked up by some engineer if the battery is damaged. or vice-versa... Thank You
May 09, 2011 | Nokia 1208 Cellular Phone
What is closed user group in nokia 1208?how can i use it?
Closed User Group (CUG) has nothing to do with the model of phone you are using. It is concerned with the service provider .
CUG means a few numbers are within a particular group and they can be calling each other without any charge.
Aug 17, 2010 | Nokia 1208 Cellular Phone
Serial number
1045-1208-8261-8319-6942-3707
Photoshop 7 serial
if this not working try these serials
Aug 21, 2009 | Adobe Photoshop 7.0 for PC
Nokia 1208 will not turn on
Maybe the panel has gone bad or the battery should be replaced. Replace the battery first.
Cheers.
May 23, 2009 | Nokia 1208 Cellular Phone
Unlock Nokia 1208
Sorry my friend, You cannot get any free unlock codes for Nokia 1208 online. Most of them will charge you anything around 10quids online to get it unlocked or you can get it unlocked in your local market for 5 quids at the most which would be cheap.
I believe the calculators wont work for these phones.
May 04, 2009 | Nokia 1208 Cellular Phone
Nokia 1208 Cellular Phone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
