Question about Garden
What is the flow rate of a milk product pump
What is the flow rate of a water pump running with 2.5 bar pressure?
    Brigadier General:
  • 4,090 Answers
More information!
what is the size of the inlet hose the outlet hose etc and what has milk to do with pressure washing machines?
We are not here to do your homework and guess the rest of the information. Contact your teacher for help
\Please rate my help++++Thanks for using FIXYA
Posted on Jun 03, 2010
Why does my coffee come out in drips not a continuous flow?
Your pump is getting weak. Pumps are made cheap now days and are part of a planned obsolescence program. That way you keep buying new coffee makers.
Oct 15, 2014 | Coffee Makers & Espresso Machines
Is it a mains fed shower
The installation must be in accordance with
Water Regulations/Bylaws.
To ensure activation of the heating elements, the
shower must be connected to a mains water
supply with a minimum running pressure of
100kPa (1.0 bar) at a minimum flow rate of eight
litres per minute (nine litres per minute for the
9.5kW rated model).
For all units the maximum static pressure must
be no greater than 1000kPa (10 bar)
If in any doubt, the pressure should be checked.
Sep 16, 2014 | Home
How can I verify that water flow rate to my Hayward H series heater is above minimum required 20 GPM?
Most pool pump/filter systems are designed to achieve the minimum recommended flow rate. A pump system with at least 1HP motor should achieve the minimum flow rate, but a 0.75HP motor would likely also achieve it. The Hayward H series heaters do not include a water flow rate sensor, but rather use a water pressure sensor to verify the pump is operating. If the system has insufficient water flow even when the pressure is within normal operating limits, the heater will likely over heat and open the water pressure relief valve located on the outlet header. This condition could occur if the down-stream line is blocked (by a closed valve or similar condition). It is important to avoid this condition since the heater will release pressure via opening a relief valve, spilling water directly out of the heater manifold.
The only adjustment for hydraulic sensing within the H series heaters is the water pressure sensor. See other articles within fixya for this procedure.
Jun 21, 2014 | Hayward H Series Pool & Spa Heater 400k...
Iam wanting to buy a 2-way cylinder to run off one of my outlets i need to know the pressure that my sk 1020 has ; in order to buy the correct one
Type Komatsu sk1020
Pump Gear
Max. flow - auxiliary hydraulic 21 gal/min 80 ltr./min
Max. pressure - auxiliary hydraulic 3,045 psi 210 bar
Control valve 3 elements fully Servo-controlled
High flow auxiliary hydraulic system "SUPER FLOW" (OPTIONAL):
Max. flow 34 gal/min 130 ltr./min
Max. pressure 3,045 psi 210 bar
cheers
Joe
www.barter-joes.com
Feb 12, 2011 | Computers & Internet
I have a grundfos mq 35 pump to boost pressure in my hot and cold system. due to loss of water recently pump ran dry and shut down. when water returned the system was restarted and pump reset. we now get...
There was possibly some damage done to the pump while it was operating dry and it in now not able to deliver the required flow of water. Pumps wear very quickly when allowed to run dry, even for a short time.
Jan 02, 2011 | Grundfos JPS4 1 HP Pressure Booster Pump
Will the Grundfos RCP-96 model work with my Rinnai tankless heater model # C85e-1?
Grundfos RCP-96 has Flow range: 0 - 27.5 U.S. GPM
According to Amazon spec sheet:
http://www.amazon.com/Grundfos-RCP-96-UP515-55SFC-Recirculator-Timer/dp/B00128BJAO
Most tankless require .4 GPM to start burner and .25 GPM to maintain burner
Rinnai does not show C85e-1 so you will have to consult your manual to see minimum water flow requirement.
http://www.rinnai.us/tankless-water-heater/
Sample manual from Rainnai mentions 'minimum flow rate' several times but doesn't give specific number. Yet promotion blurb on page 1 says "Ultra operates at a lower minimum flow rate."
http://www.rinnai.us/documentation/downloads/U290-665x0200_Condensing_Manual_EN_FR_1-2010.pdf
Another rinnai manual mentions flow rate several times in troubleshoot section yet fails to define what that rate is:
http://www.rinnai.us/documentation/downloads/U287-1833_VB_Series_R75LSi_R94LSi_R98LSi_Manual_EN_FR_EN_FR.pdf
It might seem that tankless promoters are CTA by failing to mention specific flow rate numbers.
I think tankless promotion is a definite overachiever, and vague flow rate is one tiny example.
It proves the necessity of reading whole manual and asking questions before buying a tankless.
There's another factor to consider:
All performance numbers are based on new products in ideal circumstance, and not based on a 4 year old product located in your home.
Your flow rate may vary, especially over time, and especially if water in your area is not crystal clear, and you are not diligent with correct water softener and filter.
Many factors can affect flow rates: water pressure, number of elbows, clogs in the line, sediment, size of pipe, aireators, water-saving shower heads, local water conservation policies, water well pressure, MUD district pressure issues, your home located near end of a water main, etc.
Read tankless efficiency vrs water softener
http://waterheatertimer.org/Battelle_Final_Report.pdf
Image of tankless parts vrs tank parts
http://waterheatertimer.org/images/Compare-water-heater-parts.jpg
Bradford White tankless vrs tank side by side
Lime scale does not flush out of tankless
Tankless must have water conditions with less than 11 grains hardness
"Savings falls far short of a payback," 'without comparing service costs'
http://www.pmengineer.com/Articles/Cover_Story/8cf9e86f7c298010VgnVCM100000f932a8c0____
geno_3245_197.jpg Sediment clogs tankless pressure sensor without softener.
Dec 28, 2010 | Grundfos RCP-96 Recirculation Pump for...
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Pump worked yesterday but would not shut off. I left pressure in system over night, today pressure gone, when I turn pump on, the motor runs, but no pressure or water pumped.
1.Turn off the power going to the pump.
2.Drain all the water inside the pressure tank.
3.Open the priming port plug of the pump, and fill it
full with water.
4. Put the priming port plug back in place. Close the
flow control valve and start the pump.
5. Slowly open the flow control valve to 1/8 to 1/4
open and see the flow stabilize at 20 psi of the
pressure gauge.
Hope this will help.
Nov 20, 2009 | Plumbing
After spending 880 dollors on having a head gasket water pump and radiator replaced in my 1998 pontiac sunfire 2.2 liter it has no flow thru the brand new radiator engine runs supur hot 260 degrees in 2...
YOU COULD HAVE A DEFECTIVE WATER PUMP OR THERMOSTAT ALSO RADIATOR PRESSURE CAP.MAKE SURE YOUR WATER PUMP IS BEING TURNED BY DRIVE BELT.NOT SLIPPING.MAKE SURE COOLANT SYSTEM HAS BEEN BLED AND YOU HAVE HALF ANTIFREEZE HALF WATER.CHECK YOUR CRANKCASE WHEN CAR COOLS DOWN.IF OIL STILL LOOK LIKE MILK SHAKE.YOUR NEW HEAD GASKETS LEAKING.THE MECHANIC WHO REPLACED HEAD GASKET DIDNT DECK THE HEADS.THEY PROBABLY NEED SHAVED A LITTLE SO HEAD GASKET WILL SEAL.
Nov 11, 2009 | 1998 Pontiac Sunfire
Increasing water flow rate
With a flat head screw head driver adjust the pump pressure. The screw is on the left side of the image below.
Sep 13, 2008 | Coffee Makers & Espresso Machines
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
