Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Dropped external hard drive
The drive was working normal before but I move around alot with it always in my bag, and two days ago it could not be recognised by the pc. Someone told me it may have been hit.
When you plug it in, it lights up and you hear a clicking and whirring sound which stops after about 10 seconds.
What should i do? I just need it read coz i actually wanted to format it.
    Master:
    Sergeant:
  • 383 Answers
Formatt it, it the only way the needle on the scratched disk will continue to skip and get worse
Posted on Jun 03, 2010
How might i replace this power supply?
Yes you only need to get the correct interface for the drive. ATA / Sata and they can be found cheaply on Ebay and other sellers.
May 26, 2014 | Memorex 32023223 Drive Rwdvd Dl Mrx-530le...
Hi there! i hope you can help me with my problem, im using WD harddrives the 5GB I bought it a couple of days ago and i just dropped it last from my bag, now its not working even do its readable on the...
Hard drives are very susceptible to fall damage as they have moving parts. See if it's a power problem and look inside for any internal damage. If the data inside is really important then you should bring it to a data recovery center to obtain your data. Otherwise, hand it in for warranty since it's new!
Nov 10, 2012 | Western Digital WDBAAU5000EBK-JESN Wd...
Lacie by stark external hard drive is suddenly not recognised by my computer (always worked until now) and has a permanent red light. Tried all usb ports and restarting computer. Whats wrong?
have you dropped it? it could be any number of disc errors, two of the most common errors are caused by viruses and dropping. try putting the hard drive in the freezer for a day or so in a moisture and static resistant bag. just a possibly remedy, if that doesn't work, try removing the casing on the hd and setting it as a secondary drive after you plug it inside a desktop computer.
May 09, 2011 | LaCie 500GB Starck Mobile USB 3.0 External...
Wd my book flashing blue light. sill no power up
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
I accidentally dropped my 350 GB WD Passport external hard drive and now my computer does not recognize it. Is it still repairable and can i recover the files stored there. Do you have a service center...
Try it another computer.
If it still fails, there are alot of online companies that will be able to retrieve the data for you- although Im guessing the drive its self will be unusable.
Sep 16, 2009 | Western Digital Passport WDXML800UE...
My mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 31, 2009 | Western Digital My Book Essential 500GB...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
Drop
ok the clicking sound usually means the hard drive has failed....this might sound odd but try wrapping the hard drive in a plastic bag and popping it in the freezer overnight......then connect it to your pc.....if it is recognised by the pc transfer all the data you can from it to your pc( once the drive warms up again it might not work)....failing that you need professional help with data recovery....be aware this is not cheap though
Dec 15, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
174 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
