Question about XBook P5000 (XBP50003024CH) PC Notebook
Rabbit teeth what can i do i am 12 years old and i have rabbit teeth i am very low and need help everyones calling me rabbit and i have no frends
    Brigadier General:
  • 4,090 Answers
Being low is an advantage to eating the best vegetables compared to being too high and only being able to nibble the tops of old dying leaves.!
Well rather than rabbit on about it why not make a joke of it. Sometimes the taunts of friends that seem cruel can work to your advantage
Did you Know Shaun Connery had the same problem But he got the job as 007.
Ashton Kucher, Justin Beiber, Arnold Shwartznegger and many others all had "rabbit teeth" when they were younger.
Eventually the other teeth catch up with the growth and then they won't be as obvious
By the time you are 15 your teeth will be quite different. Your two front teeth are usually older than all the other teeth so they grow more quickly. Often babies first teeth are the two front ones. They are the first to fall out and be replaced too so they are still the oldest teeth in your mouth.
Stick with it kid and continue to smile flashing the best and strongest teeth on the block
Posted on Jun 03, 2010
    President:
  • 548 Answers
Ignore them and be yourself. Eventually they will came and ask for your help. If you ignore them it will hurt them more if you start fighting them. You have to be smarter than them.
What is the main differences between cosmetic teeth whitening treatment and the teeth whitening treatment performed at the dental office?
The cosmetic teeth whitening treatment is not permanent and gives result only for sometime while with teeth whitening treatment (Zahnaufhellung M?nche) you get free for some years like 5 years. So if you are planning to whiten your teeth i would prefer teeth whitening treatment. Good Luck.
Mar 30, 2014 | Health & Beauty
Insulation breakdown
Hi.
I have not seen a subzero unit that could not be repaired, even thirty years old unit can be repaired. With that being said, I would call subzero directly to ask for a certified servicer in your area to take care of your unit. Here is a link for their website to help you Contact and Support they will get you a person knowledgeable to correct your issue. FYI not everyone can work on SubZero unit. This unit if 12 1/2 years old is just a teenager to this manufacture, no worries. They can last over 30 years, I have seen them and repaired them.
I am here if you need help in SoCal.
Jun 08, 2013 | Sub-Zero Refrigerators
Hi, I have a 1997 GMC Sierra (5.7 L). Once every two weeks or so it won't start. I just get one click. If I wait a little while (15 sec to 15 minutes) and try to start it, it starts perfectly. ...
Check the starter it could a bad cross over or the teeth on the catch wheel (or what ever it is called) could be broken and by attempting to start it you are bypassing the broken teeth and it will catch allowing the vehicle to start. Also just to be thorough double check the electrical from the batt to the alt, ignition switch and the starter.
Jun 26, 2011 | 1997 GMC Sierra
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Trying to get DTV, I can't figure it out
If you are in the US you need a digital reciever, rabbit ears or otherwise and have since February. That when all US broadcasters switched to digital broadcast. If it's more than about 5 years old you will likely have to purchase a new TV.
Jun 02, 2009 | Akai LCT3201TD 32 in. LCD Television
Needs a thermostat
go to sears.com and put the model number and you might be able to order one from there.
Apr 25, 2009 | Heating & Cooling
Won't start
12 year old Mitshubishis usualy only need a dozen or so capacitors to get them running again but at 12 years old bet the CRTs are worn and the picture quality will be low, We have a saying in the TV repair business that might help you out, TV's age like cats, so you have a 12 year old cat what do you do?
Apr 02, 2008 | Mitsubishi VS-50607 50" Rear Projection...
XBook P5000 (XBP50003024CH) PC Notebook Logo
78 people viewed this question
Top XBook Computers & Internet Experts
David Payne
David Payne
Are you a XBook Computer and Internet Expert? Answer questions, earn points and help others
