Question about HP OfficeJet 7310 All-In-One InkJet Printer
How do I replace the scanner motor? I have the motor...I just need instructions on how to install it in the 7310 Officejet all-in-one model.
  • pachri_7 Jun 03, 2010
    God bless you! I hope this works. I'm accepting this on sheer faith! I'll try it out tomorrow and let you know! P. Christy
    President:
  • 1,194 Answers
Here are the steps :-
1. First you have to remove the lite gray trim from the top back of the printer. Stand behind the printer and pull the top of the trim towards you.
2. Once the trim is removed disconnect the brown wire and the large pin assembly coming from the scanner section to the ADF Assembly. Lift and remove the top of the printer.
3. Using a T10 screw driver or a flathead screwdriver that fits firm remove all visible screws.
4. Facing the printer there is a small piece of plastic and glass. Take you screw driver and lift this up using the screw hole.
5. Now there should be two more screws to remove.
6. Standing facing the printer take the top of the control panel and pull it towards you. It will snap out exposing two more screws to remove.
7. Once all the screws are remove lift up on the glass and trim to expose the scanner and motor assemblies.
8. Remove the two screws hold the motor in place. Remove the scanner assembly from the belt and guide.
9. Lift up the steel rod and remove the belt by pushing down on the spring at the other end from the motor.
10. Now you need to reverse the instruction to put it back together.
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on Jun 03, 2010
My program for Officejet 7310 all in one is installed but whenever I try to scan, I get a message that the software needs to be installed. What do I do?
Try going to Hp soltions for updated drivers. Also windows has it own scanning drivers. Try going to control panel and selecting scanner devices, and go through the installation wizard to install a scaning device, if your scanner is not listed then just click on install new device.
Oct 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 7310 will not scan. Get message, must install program. Program is installed and has been re-installed 3 times.
i have the same problem:( i figured a way around it until someone posts the real answer. if you have an application like adobe, you can import photos from inside the app. also, vista gave me a hard time recognizing the scanner(as it seems to do with a lot of things), it won't work if you can't see the scanner in your control panel.
Jun 11, 2009 | HP OfficeJet 7310 All-In-One InkJet...
You should be able to go to www.hp.com and download drivers from support.
Oct 31, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7310 all-in-one download
Hi Vicky, you can click the HP link below, for setup and install of your HP Officejet 7310 All-in-One printer.
http://h10025.www1.hp.com/ewfrf/wc/setupCategory?lc=en&cc=us&dlc=en&product=391182&lang=en
Just take your time, everything will be fine.
If I can be of more service, just ask.
Good Luck!
Mike
Mar 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7310 All-in-One Scanner problem
If the HP service cant help, then try to get a exchange, the machine usually have a warranty.
Jul 10, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
